Старый 24.11.2009, 15:05   #1
Kashperuk Ivan: SysCompilerTarget - compiling X++ code without showing the compilation window
Источник: http://kashperuk.blogspot.com/2009/1...ng-x-code.html
I have been posed with a question about how to avoid showing the compilation window during compilation of some X++ code (When doing compilation from code, naturally).
So I decided to post a possible solution for this question, re-using one of my previous posts about ClassBuild class.
Basically, AOTcompile method on TreeNode class supports an optional flag, controlling the compilation output:
An integer that indicates whether output should be sent to the message box. If the value 1 is passed, no output is sent to the message box. The default value is 0. This parameter is optional.
So all we need to do now is change the compilation output target to Message Window. Looking at the SysCompilerSetup form code, it's rather easy to come up with the following code:
static void SysCompilerTargetExample(Args _args)
ClassBuild classBuild;
DictClass dictClass;
SysCompilerTarget targetOrig;
// Setting Compilation Target = Message Window
targetOrig = SysUserInfo::compilerTarget();
SysUserInfo::compilerTarget(SysCompilerTarget::MessageWindow);
SysCompilerOutput::setCompilerTarget(SysCompilerTarget::MessageWindow);
SysCompilerOutput::updateParm();
// Building the class with 1 method
classBuild = new ClassBuild("TRN_ClassBuild", false);
classBuild.addMethod("test", 'void test()\n{\n}');
classBuild.addSourceToMethod("test", @"
info('We created a Class and can call its methods');");
// The actual compilation. Note the _flag argument == 1
classBuild.classNode().AOTcompile(1);
// Call the class method to show that we are done and the code is compiled
dictClass = new DictClass(className2Id(classBuild.name()));
dictClass.callObject('test', dictClass.makeObject());
// Restoring Compilation Target to its original value
SysUserInfo::compilerTarget(targetOrig);
SysCompilerOutput::setCompilerTarget(targetOrig);
Don't forget to restore the original settings after the compilation is complete, as shown above.
Kashperuk Ivan: Tool for protecting your Dynamics AX source code Blog bot DAX Blogs 0 12.12.2008 04:07
Kashperuk Ivan: Dynamics AX Tutorials - Tutorial 2 - Classes\Box Blog bot DAX Blogs 0 25.04.2007 22:23
Kashperuk Ivan: Description of ClassBuild class:Today I want to ... Blog bot DAX Blogs 0 26.01.2007 05:51
Часовой пояс GMT +3, время: 17:03.
