Старый 30.07.2008, 20:05   #1
Мир CRM: The key specified to compute a hash value is expired, only active keys are valid
Источник: http://feeds.feedburner.com/~r/crmwo.../~3/342878831/
С выходом Dynamics CRM 4.0 очень часто встечаюсь с проблемой когда не возможно провести какие либо действия или иной раз не возможно вообще залогониться на CRM 4.0. При этом появляется ошибка:
Microsoft CRM Error Report:
Error Description:
The key specified to compute a hash value is expired, only active keys are valid. Expired Key : CrmKey(Id:5098e800-ca3d-dd11-b596-001e0b5d784e, ScaleGroupId:00000000-0000-0000-0000-000000000000, KeyType:CrmWRPCTokenKey, Expired:True, ValidOn:06/19/2008 06:36:11, ExpiresOn:07/22/2008 06:36:11, CreatedOn:06/19/2008 06:36:11, CreatedBy:CRMWorld\User.
Error Details:
The key specified to compute a hash value is expired, only active keys are valid.  Expired Key : CrmKey(Id:5234e800-ca3d-dd11-b596-001e0bety784r, ScaleGroupId:00000000-0000-0000-0000-000000000000, KeyType:CrmWRPCTokenKey, Expired:True, ValidOn:06/19/2008 06:36:11, ExpiresOn:07/22/2008 06:36:11, CreatedOn:06/19/2008 06:36:11, CreatedBy:CRMWorld\User.
Full Stack:
[CrmException: The key specified to compute a hash value is expired, only active keys are valid.  Expired Key : CrmKey(Id:5098e800-ca3d-dd11-b596-001e0b5d784e, ScaleGroupId:00000000-0000-0000-0000-000000000000, KeyType:CrmWRPCTokenKey, Expired:True, ValidOn:06/19/2008 06:36:11, ExpiresOn:07/22/2008 06:36:11, CreatedOn:06/19/2008 06:36:11, CreatedBy:CRMWorld\User.]
   at Microsoft.Crm.CrmKeyService.ComputeHash(CrmKey key, Guid scaleGroupId, HashParameterBase[] parameters)
   at Microsoft.Crm.CrmKeyService.ComputeHash(CrmKey key, HashParameterBase[] parameters)
   at Microsoft.Crm.Application.Security.WRPCContext.ComputeWrpcTokenHash(CrmKey key, String actionPageUrl, DateTime timestamp)
   at Microsoft.Crm.Application.Security.WRPCContext.GenerateToken(String pageUrl, DateTime timestamp)
   at Microsoft.Crm.Controls.Header.Render(HtmlTextWriter output)
   at ASP.crmworld_home_home_debug_aspx.__Render__control1(HtmlTextWriter __w, Control parameterContainer)
   at System.Web.UI.Control.RenderChildrenInternal(HtmlTextWriter writer, ICollection children)
   at System.Web.UI.Page.Render(HtmlTextWriter writer)
   at System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint)
[HttpUnhandledException: Exception of type 'System.Web.HttpUnhandledException' was thrown.]
   at System.Web.UI.Page.HandleError(Exception e)
   at System.Web.UI.Page.ProcessRequest(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint)
   at System.Web.UI.Page.ProcessRequest()
   at System.Web.UI.Page.ProcessRequest(HttpContext context)
   at ASP.crmworld_home_home_debug_aspx.ProcessRequest(HttpContext context)
   at System.Web.HttpApplication.CallHandlerExecutionStep.System.Web.HttpApplication.IExecutionStep.Execute()
   at System.Web.HttpApplication.ExecuteStep(IExecutionStep step, Boolean& completedSynchronously)
OtherMessage:
ErrorNumber:
0x8004A106
Так вот, проблема эта возникает при неисправности сервиса “MicrosoftCRMAsynchronousProcessingService”. Проверьте не остановлен ли этот сервис и если так и есть, то запустите его.
С Уважением,
Денис
За это сообщение автора поблагодарили: kosten (1), Degun (1).
Мир CRM: Предварительный обзор Mobile Express для Microsoft Dynamics CRM 4.0 Blog bot Dynamics CRM: Blogs 2 06.10.2011 11:23
Microsoft Dynamics CRM Team Blog: Building Rich-Client Dashboards for Microsoft Dynamics CRM with Windows Presentation Foundation Blog bot Dynamics CRM: Blogs 1 31.03.2009 13:24
Мир CRM: Улучшение Dynamics CRM 4.0 производительности и безопасности данных под SQL Server 2008 Blog bot Dynamics CRM: Blogs 0 03.02.2009 02:07
Мир CRM: Академия для партнёров по Microsoft Dynamics CRM Blog bot Dynamics CRM: Blogs 0 02.02.2009 01:05
Часовой пояс GMT +3, время: 11:29.
