Старый 19.06.2022, 22:12   #1
D365FO: SysMultiTableLookup - dynamic lookups based on multiple tables
Источник: http://alexvoy.blogspot.com/2022/06/...p-dynamic.html
Yes, guys, sometimes they come back!
Fourteen years ago Vania Kashperuk created a class which became classics: SysMultiTableLookup. It made possible to create lookups based on multiple tables. Some people are still looking for it in vain among the standard classes. So I decided to create a new version of it for D365FO.
It combines supporting for both lookup and lookupReference methods: performFormLookup and performFormReferenceLookup.
Vania added a tutorial form to his class, so did I. There is a form in the project, which shows how unbounded form controls can be looked up with fields and display methods from joined tables as well as the case with aggregation and a CustTable data source to demonstrate a lookup for a reference group.
Take note that I did not implement resolving and have not tested it thoroughly, neither.
Feel free to use it and elaborate at your own risk.
The whole project tmxSysMultiTableLookup is here in https://github.com/wojzeh/tmxSystemTools
The only class is here
<div style="background: rgb(255, 255, 255); border-color: gray; border-image: initial; border-style: solid; border-width: 0.1em 0.1em 0.1em 0.8em; border: solid gray; overflow: auto; padding: 0.2em 0.6em; width: auto;">///
/// Multi table lookup. D365FO version based on the original by Vanya Kashperuk
/// http://kashperuk.blogspot.com/2008/0...c-lookups.html
public class tmxSysMultiTableLookup extends SysTableLookup
FormBuildInt64Control recIdSelectModeControl;
boolean isReference;
/// Is reference lookup
/// boolean
/// True if Reference
protected boolean parmIsReference(boolean _parm = isReference)
isReference = _parm;
return isReference;
/// Places the specified form into the correct lookup selection mode.
/// The form to be put into lookup selection mode.
protected void setSelectMode(FormRun _formRun)
if(isReference)
if (!recIdSelectModeControl)
throw(error(Error::wrongUseOfFunction(funcname())));
_formRun.selectRecordMode(_formRun.control(recIdSelectModeControl.id()));
else
super(_formRun);
/// Constructs tmxSysMultiTableLookup for a formcontrol with a given query
/// Target form Reference group control
/// Query
/// Use input value
/// AmbiguousReferenceResolver
/// Instance of tmxSysMultiTableLookup
static tmxSysMultiTableLookup newReferenceParameters(FormReferenceControl _callingControl, Query _query, boolean _useLookupValue = true)
tmxSysMultiTableLookup sysTableLookup = tmxSysMultiTableLookup::construct();
if(_query.dataSourceCount() < 1)
throw error(@"Query needs to be defined before building the lookup");
sysTableLookup.parmIsReference(true);
sysTableLookup.parmQuery(_query);
sysTableLookup.parmCallingControl(_callingControl);
sysTableLookup.parmUseLookupValue(_useLookupValue);
return sysTableLookup;
/// Target form control
/// Query
/// Use input value
static tmxSysMultiTableLookup newParameters(FormControl _callingControl, Query _query, boolean _useLookupValue = true)
/// Instantiates tmxSysMultiTableLookup
/// tmxSysMultiTableLookup
static tmxSysMultiTableLookup construct()
return new tmxSysMultiTableLookup();
/// Adds form control
/// Datasource number in the query
/// Field num
/// Return item
/// Method name
/// Label
void addLookupControlMulti(int _dataSourceNo, fieldId _fieldId, boolean _returnItem, str _methodName, str _label)
lookupItems += [[_dataSourceNo, _fieldId, _returnItem, _methodName]];
if (_label)
this.setLabel(_label);
/// Adds field as form control
/// Method name
/// Label
void addLookupMethodMulti(str _methodName, int _dataSourceNo = 1, str _label ="")
this.addLookupControlMulti(_dataSourceNo, 0, false, _methodName, _label);
/// Field num
/// Return item
/// Label
void addLookupFieldMulti(fieldId _fieldId, int _dataSourceNo = 1, boolean _returnItem = false, str _label = '')
if (_dataSourceNo > query.dataSourceCount())
throw error(Error::wrongUseOfFunction(funcName()));
this.addLookupControlMulti(_dataSourceNo, _fieldId, _returnItem, '', _label);
/// Chooses LinkType appropriate to JoinMode
/// JoinMode
/// FormLinkType
protected FormLinkType joinMode2LinkType(JoinMode _joinMode)
switch (_joinMode)
case JoinMode::InnerJoin:
return FormLinkType::InnerJoin;
case JoinMode::OuterJoin:
return FormLinkType::OuterJoin;
case JoinMode::ExistsJoin:
return FormLinkType::ExistJoin;
case JoinMode::NoExistsJoin:
return FormLinkType::NotExistJoin;
/// Configures the data source of the lookup form.
/// FormBuildDataSource
/// QueryBuildDataSource
protected void configureLookupDataSourceMulti(FormBuildDataSource _formBuildDataSource, QueryBuildDataSource _queryBuildDataSource)
this.configureLookupDataSource(_formBuildDataSource);
if(_queryBuildDataSource.embedded()) //joined() or level() > 1
_formBuildDataSource.linkType(this.joinMode2LinkType(_queryBuildDataSource.joinMode()));
_formBuildDataSource.joinSource(_queryBuildDataSource.parentDataSource().name());
/// Builds grid form control
/// FormBuildGridControl
/// Form
protected FormBuildGridControl buildGridMulti(FormBuildGridControl _formBuildGridControl, Form _form)
FormBuildDataSource formBuildDataSource;
FormBuildControl formBuildControl;
Object obj;
boolean returnItem;
str method;
int fieldId;
int i;
boolean lookupFieldSet = false;
int dataSourceNo;
fieldId recIdFieldId;
boolean firstDS = true;
// add fields and display methods for all given data sources
for (i = 1; i 1)
throw error("Multiple temporary datasource lookups are not supported");
formDataSource.init();
//BP deviation documented
formDataSource.cursor().setTmp();
formDataSource.cursor().setTmpData(tmpBuffer);
this.setSelectMode(formRun);
this.buildSelectionListMulti(formDataSource.query());
this.addFilter(formRun);
return formRun;
/// Creates selection list from a given query
/// Query
protected void buildSelectionListMulti(Query _query)
boolean returnItem;
str method;
int fieldId;
int i;
int dataSourceNo;
SelectionField fieldKind()
int j;
QueryBuildFieldList qbfl;
qbfl = _query.dataSourceNo(dataSourceNo).fields();
for (j = 1; j
Alexdmeyer: Creating a Zip File From Multiple MemoryStreams in D365FO Blog bot DAX Blogs 0 30.08.2021 20:12
Alexdmeyer: How to Apply Multiple XDS Policies to the Same Role in D365FO Blog bot DAX Blogs 0 26.07.2021 22:19
Alexdmeyer: How to Apply D365FO Extensible Data Security Based on the Current User Blog bot DAX Blogs 0 21.06.2021 18:13
stoneridgesoftware: Working With Kernel Based Classes and AOT Based Tables in Dynamics AX Blog bot DAX Blogs 0 19.10.2017 20:11
Kashperuk Ivan: SysMultiTableLoookup - dynamic lookups based on multiple tables Blog bot DAX Blogs 11 16.10.2008 12:26
Часовой пояс GMT +3, время: 07:14.
