Старый 23.12.2021, 05:30   #1
domhk: Taking JSON input with D365 service and deserialize into contract class
Источник: https://domhk.blogspot.com/2021/12/t...rvice-and.html
Recently I wanted to create a custom serivce in D365 taking in a JSON input. I did my usual google search but ended up needing additional trial and error to complete the use case. Here I'll share the solution I have..
Firstly, create a contract class which represent the a Json object
/// The Student Information object contains the Student ID and Name
[DataContractAttribute]
class StudentInfoContract
str studentId;
str studentName;
[DataMemberAttribute("Student Id")]
public str parmStudentId(str _studentId = studentId)
studentId = _studentId;
return studentId;
[DataMemberAttribute("Student Name")]
public str parmStudentName(str _studentName = studentName)
studentName = _studentName;
return studentName;
Then, in the service contract class, define a List of Str which will take in the Json
/// Contains a list of students
class StudentsContract
List studentList = new List(Types::String);
DataMemberAttribute("Student list"),
DataCollectionAttribute(Types::Class, classStr(StudentInfoContract))
public List parmStudentList(List _studentList = studentList)
if (!prmIsDefault(_studentList))
studentList = _studentList;
return studentList;
At run time, when calling code provides a list of Json objects, it'll be come a list of JObjects in X++. We'll loop through the list and use FormDeserializer to deserialize each JObject into a contract instance
List studentList = StudentsContract.parmStudentList();
ListEnumerator enumerator = studentList.getEnumerator();
while (enumerator.moveNext())
Newtonsoft.Json.Linq.JObject jObj = enumerator.current();
studentInfoContract = FormJsonSerializer::deserializeObject(classNum(StudentInfoContract),jObj.ToString());
str studentId, studentName;
studentId = studentInfoContract.parmStudentId();
studentName = studentInfoContract.parmStudentName();
Info(strFmt("Studnet # %1: %2", studentId, studentName));
In the end it's quite simple, and also no need to create C# class representing the data contract as well.
Старый 24.12.2021, 12:00   #2
gl00mie is offline
gl00mie
3,684 / 5813 (201) ++++++++++
Это называется "закат солнца вручную". В контрактах сервисов коллекции стоит "декорировать" атрибутом AifCollectionTypeAttribute - тогда и не придется их десериализовывать вручную.
  AifCollectionTypeAttribute("return", Types::Class, classStr(StudentInfoContract)),
  AifCollectionTypeAttribute("_studentList", Types::Class, classStr(StudentInfoContract))
PS. Сама постановка задачи уже наводит на подозрения:
Зачем это, спрашивается, в D365FO делать кастомный сервис, который на входе получал бы JSON, а не нормальный типизированный контракт?..
Последний раз редактировалось gl00mie; 24.12.2021 в 12:03.
Старый 24.12.2021, 13:41   #3
пробелы в названии...
Какие заботливо разложенные грабли.
Старый 29.12.2021, 15:20   #4
DSPIC is offline
DSPIC
Боец
1,077 / 1243 (44) ++++++++
Давайте разбираться.
Про закат вручную:
Тут не вручную, а помощью стандартного класса FormJsonSerializer (D365).
Во-вторых - задача, когда на вход извне впаривают сырой JSON (или XML) стоит сплошь и рядом: "Мы вам будем передавать XML\JSON строку и точка. Мы не можем переделать нашу систему под вашу, чтобы завязаться на ваш веб сервис. Или можем, но за большие деньги, где-то через года пол. Наши клиенты по всему миру, мы работаем только так".
А какие есть альтернативы? Чаще всего для jSON встречается ручной парсинг строк strScan, strFind и т.д. Изредка попадаются продвинутые выринты - используют Newton.JSon.dll. C XML немного проще - стандартный класс пробега по XML с большего освоили, но это всё-равно абсолютный хардкод.
Про аттрибут:
Класс FormJsonSerializer понимает только DataCollectionAttribute. Более того, для дата-контрактов с их parm* методами этот аттрибут идеально подходит (на входе один параметр с таким же типом что и на выходе).
AifCollectionTypeAttribute пришел из AX2012. Он больше подходит для описания сервис-операций, где может быть несколько входных параметров, разных типов, а на выходе что-то третье. Но в AX2012 других выриантов не было.
Для сравнения:
// D365:
// ИЛИ AX2012:
Т.е.второй вариант избыточный для дата-контрактов имхо.
Единственное - не уверен, понимает ли сериализатор D365 этот атрибут при описании контрактов для веб-сервисов - не приходилось применять, но как бы must Have.
В XML так нельзя. В jSON можно.
Претензия к автору блога у меня только одна: корее всего куски кода он где-то вырвал и не тестировал. Или спешил, промазал и недопроверил
естественно, вот на этом получит моментальный взлёт, пытаясь закастить аксаптовский класс в CLR тип.
Вообще не понятно, как это должно было работать. С другой стороны - юридически, он прикрылся "This posting is provided "AS IS" with no warranties, and confers no rights."
Наверное он так хотел сделать:
public static void main(Args _args)
        StudentsContract        studentsContract;
        void addStudent(str _id, str _name)
            StudentInfoContract student = new StudentInfoContract();
            student.parmStudentId(_id);
            student.parmStudentName(_name);
            studentsContract.parmStudentList().addEnd(student);
        studentsContract = new StudentsContract();
        studentsContract.parmStudentList(new List(Types::Class));
        addStudent("1", "First");
        addStudent("2", "Second");
        // Serialize
        str jSon = FormJsonSerializer::serializeClass(studentsContract);
        // Deserialize
        studentsContract = FormJsonSerializer::deserializeObject(classNum(StudentsContract), jSon);
        ListEnumerator enumerator = studentsContract.parmStudentList().getEnumerator();
            StudentInfoContract student = enumerator.current();
            info(strFmt("Studnet # %1: %2", student.parmStudentId(), student.parmStudentName()));
Последний раз редактировалось DSPIC; 29.12.2021 в 15:25.
За это сообщение автора поблагодарили: sukhanchik (4), vmoskalenko (6).
Старый 29.12.2021, 22:57   #5
gl00mie is offline
gl00mie
Имя стандартного класса как бы намекает, что он задумывался больше для форм, чем для сервисов
Во-вторых - задача, когда на вход извне впаривают сырой JSON (или XML) стоит сплошь и рядом: "Мы вам будем передавать XML\JSON строку и точка. Мы не можем переделать нашу систему под вашу, чтобы завязаться на ваш веб сервис.".
Наверно, так тоже бывает, но в данном случае автор сам же пишет: я решил сделать сервис, вот его контракт, в контракте есть коллекция классов. Он не пишет, что парсит чей-то чужой JSON - напротив, он получает на вход именно тот контракт, который заказывал, только "недодесериализованный", полусырой, так сказать. Скажу больше: кастомные сервисы в D365FO доступны извне и как REST (с JSON-ом на входе), и как SOAP-сервисы (c XML на входе), но из-за того, что автор использовал не тот атрибут в контракте, он и для SOAP-варианта своего сервиса получил полусырой WSDL, в котором коллекция классов будет представлена как просто абстрактный массив не пойми чего. Использованием неправильного атрибута автор и себе лишнюю работу создал, и клиентам, которые попытаются WSDL сервиса посмотреть, проблем подкинул.
Про аттрибут:
Идеально подходит для любителей ручного разбора JSON и полусырых WSDL-ей
Какая разница, откуда пришел атрибут? DataContractAttribute тоже был в AX2012, и что, может, на этом основании его не использовать? Приложение D365FO на 90-95% - это приложение AX2012 R3, и если какие-то вещи из AX2012 продолжают успешно работать в D365FO, а альтернатива им - закат солнца вручную, то какой смысл от них отказываться?
Либо на входе сервисного метода - коллекция одних типов, а на выходе - коллекция других типов.
Во-первых, были альтернативы, посмотрите хотя бы на полёт фантазии в FormLetterContract:
[DataMemberAttribute]
public str parmDataSourceRecordsPacked(str _dataSourceRecordsPacked = '')
    if (prmIsDefault(_dataSourceRecordsPacked))
        return SysOperationHelper::base64Encode(this.parmDataSourceRecordMapPacked());
    return SysOperationHelper::base64Encode(this.parmDataSourceRecordMapPacked(SysOperationHelper::base64Decode(_dataSourceRecordsPacked)));
Мощно?!
Во-вторых, никто не мешал даже в AX2012 определить свой класс атрибута и парсить вручную что угодно аналогично тому, как это теперь делает FormJsonSerializer.
Для сравнения:
// D365:
// ИЛИ AX2012:
Мы же помним, что кастомные сервисы в D365FO доступны извне одновременно и как REST, и как SOAP-сервисы, причем в REST метаданные, мягко говоря, победнее. Сделаем в контракте два поля, одно - studentList - с атрибутом DataCollection, а другое - studentListAif - с атрибутом AifCollectionType. И посмотрим теперь, как такие поля в контракте сервиса D365FO выглядят в WSDL:
PHP код:
<xs:complexType name="StudentsContract">
xs:complexContent mixed="false">
xs:extension xmlns:q8="http://schemas.datacontract.org/2004/07/Microsoft.Dynamics.Ax.Xpp" base="q8:XppObjectBase">
xs:sequence>
xs:element xmlns:q9="http://schemas.microsoft.com/2003/10/Serialization/Arrays"
minOccurs="0" name="StudentList"
nillable="true" type="q9:ArrayOfanyType"/>
xs:element minOccurs="0" name="StudentListAif"
nillable="true" type="tns:ArrayOfStudentInfoContract"/>
xs:sequence>
xs:extension>
xs:complexContent>
xs:complexType>
xs:element name="StudentsContract" nillable="true" type="tns:StudentsContract"/>
xs:complexType name="ArrayOfStudentInfoContract">
xs:sequence>
xs:element minOccurs="0" maxOccurs="unbounded" name="StudentInfoContract" nillable="true" type="tns:StudentInfoContract"/>
xs:sequence>
xs:complexType>
xs:element name="ArrayOfStudentInfoContract" nillable="true" type="tns:ArrayOfStudentInfoContract"/>
xs:complexType name="StudentInfoContract">
xs:extension xmlns:q10="http://schemas.datacontract.org/2004/07/Microsoft.Dynamics.Ax.Xpp" base="q10:XppObjectBase">
xs:sequence>
xs:element minOccurs="0" name="StudentId" nillable="true" type="xs:string"/>
xs:element minOccurs="0" name="StudentName" nillable="true" type="xs:string"/>
xs:sequence>
xs:extension>
xs:complexContent>
xs:complexType
Видим, что для DataCollection мы получили StudentList в виде ArrayOfanyType, без какой-либо дальнейшей детализации.
А для AifCollectionType мы получили StudentListAif в виде ArrayOfStudentInfoContract с полной разблюдовкой: мы видим в WSDL и сам StudentInfoContract, и то, что он состоит из двух строковых полей: StudentId и StudentName. И повторюсь: для AifCollectionType платформа занимается тем, что десериализует для вашего сервиса коллекцию объектов и заодно проверяет, что объекты в коллекции - нужного типа, а не абы что. По-моему, это всё в совокупности стоит того, чтобы добавить методу лишний атрибут.
Последний раз редактировалось gl00mie; 29.12.2021 в 23:28.
Старый 30.12.2021, 00:59   #6
DSPIC is offline
DSPIC
Боец
Оккей, давай по существу. Как будешь решать задачу десериализации?
Recently I wanted to create a custom service in D365 taking in a JSON input.
У тебя на входе строка JSON.
Старый 30.12.2021, 01:42   #7
ax_mct is offline
ax_mct
Banned
2,548 / 1091 (0) ++++++++
Не уверен что в тему так как возможно в теме больше про паттерны дизайна,
но в AX 2012 мне очень пригодился метод
RetailCommonWebAPI::getMapFromJSONString()
Старый 30.12.2021, 17:26   #8
gl00mie is offline
gl00mie
Оккей, давай по существу. Как будешь решать задачу десериализации? У тебя на входе строка JSON.
Не нужно пытаться подменять одну задачу на другую в попытках доказать свою правоту При разработке кастомного сервиса в D365FO нет задачи десериализации строки JSON на входе (хотя бы потому, что на входе может быть XML - если сервис будут дергать как SOAP). Нужно думать о том, чтобы разработать внятный контракт сервиса, а об остальном должны позаботиться платформа и клиент, вызывающий сервис. Если вы разработали контракт, в котором передается строка в JSON (ну мало ли - обстоятельства или контрагенты заставили), то это - совсем другая история. Я приводил штатный пример из FormLetterContract: на вход может подаваться строка, где в base64 закодирован бинарный контейнер, в который запакована коллекция записей произвольной таблицы. Ну и что это доказывает? Что все гланды на свете надо удалять через.. выхлопную трубу?
Платформа заботится о разработчике, беря на себя десериализацию и проверку корректности входного контракта сервиса - ей надо лишь чуть подсказать с помощью правильных атрибутов, если на входе ожидаются объекты-коллекции. Вообще вся тема, как мне лично представляется, не про вопрос выбора того или иного атрибута для поля-коллекции в контракте, не про то, что какие-то атрибуты кому-то нравятся больше, а кому-то - меньше, что от одних исходит аромат высоких стандартов разработки, а от других - затхлый запашок предыдущей версии системы, которая уже и с поддержки снята, и AIF-а вашего в новой версии нет, и вообще... Тема, по-моему, про то, сколько проблем и ручного труда можно поиметь, если использовать неправильный атрибут. Используйте правильный атрибут - и тратьте больше времени на бизнес-логику, а не на ковыряние в JSON-ах, парных квадратных скобках и форматах кодирования дат. Это всё уже давно решено в платформе, зачем изобретать велосипед?..
PS. С наступающим Новым годом
Старый 30.12.2021, 19:57   #9
DSPIC is offline
DSPIC
Боец
Сообщение от Fattung
Taking JSON input with D365 service and deserialize into contract objects
Как по мне - именно задачу десериализации JSON строки автор и пытается решить. Ну приходит она к нему через кастомный веб сервис, ровно как приходила бы из какого-то файла на FTP или ещё откуда-то - без разницы.
Ок. А какую по-твоему задачу он решает?
d365fo, json, интеграция
Navigate Into Success: Passing JSON from JavaScript to C/AL Blog bot Dynamics CRM: Blogs 0 31.12.2014 10:00
Navigate Into Success: Long time no see, Vienna, Nashville, demo gods, and other things Blog bot Dynamics CRM: Blogs 0 09.10.2013 01:15
Navigate Into Success: Web Reference vs. Service Reference, Part 3 Blog bot Dynamics CRM: Blogs 0 31.01.2012 04:44
Navigate Into Success: Web Reference vs. Service Reference, Part 2 Blog bot Dynamics CRM: Blogs 0 30.01.2012 11:04
Creating Custom Dynamics AX Services Blog bot DAX Blogs 0 17.12.2008 12:05
Часовой пояс GMT +3, время: 19:59.
