Старый 13.07.2021, 20:15   #1
Setup Business Event Endpoint with MuleSoft
Источник: http://alexvoy.blogspot.com/2021/07/...oint-with.html
[COLOR=rgba(0, 0, 0, 0.9)]When it comes to setting up a Business Event BE endpoint: D365FO just sends a basic data contract (“payload”) via POST method.[/COLOR]
[COLOR=rgba(0, 0, 0, 0.9)]So, in fact we can use Microsoft Power Automate endpoint type to interact with your eventual MuleSoft HTTP listener.[/COLOR]
[COLOR=rgba(0, 0, 0, 0.9)]A simple app (a flow) in MuleSoft Design Center consisting of two steps: HTTP listener and Logger.[/COLOR]
[COLOR=rgba(0, 0, 0, 0.9)][/COLOR]
[COLOR=rgba(0, 0, 0, 0.9)]This basic BE data contract info to add a new type:[/COLOR]
[COLOR=rgba(0, 0, 0, 0.9)]{"TestField":"","BusinessEventId":"","ControlNumber":0,"EventId":"","EventTime":"/Date(-2208988800000)/","MajorVersion":0,"MinorVersion":0}[/COLOR]
[COLOR=rgba(0, 0, 0, 0.9)]For you particular case you can use pre-generated scheme for your new Business Event.[/COLOR]
[COLOR=rgba(0, 0, 0, 0.9)]After that you can add other steps to your MuleSoft app.[/COLOR]
waldo: Microsoft Dynamics 365 Business Central Virtual Event, June 3rd, 2020 Blog bot NAV: Blogs 0 15.05.2020 00:15
sertandev: How to integrate D365FO with Microsoft Flow using the new Business Events Blog bot DAX Blogs 0 23.05.2019 16:11
alexef: Sample Extension v2.0 — Dynamics NAV / AL extension / SaaS — ALF Export Setup Tabs to Excel Blog bot NAV: Blogs 3 05.10.2018 23:13
alexef: How to add a field to Item Card in Business Central Blog bot NAV: Blogs 0 22.05.2018 20:11
Часовой пояс GMT +3, время: 00:01.
