Старый 20.01.2019, 08:33   #1
cleverax: The use of “Planning item” production type for grading process in manufacturing
Источник: https://cleverax.wordpress.com/2019/...manufacturing/
There is a Production type field on the released product form that drives product behavior in production, for example, if you set it to None you may notice that you cannot create neither Formula nor Bill of materials version for it (the buttons are simply grayed out) which also means that you won’t be able … Continue reading The use of “Planning item” production type for grading process in manufacturing →
dynamicsaxse: November 2018 Release – Dynamics AX2012 R3 update Blog bot DAX Blogs 0 15.11.2018 09:11
Microsoft Dynamics AX 2012 Process Manufacturing Production and Logistics R2 Vadik DAX: База знаний и проекты 4 27.10.2014 17:04
atinkerersnotebook: Configuring Lean Manufacturing in Dynamics AX 2012 Blog bot DAX Blogs 1 12.08.2013 00:15
dynamicsaxtraining: Production life cycle Blog bot DAX Blogs 0 16.07.2011 01:23
Часовой пояс GMT +3, время: 14:02.
