Старый 07.11.2018, 01:13   #1
sashanazarov: Create LedgerDimension from main account and financial dimensions
Источник: http://sashanazarov.blogspot.com/201...from-main.html
The following code will (hopefully) keep generating valid LedgerDimension values, even after account structures or advanced rule structures are modified.
In the example below, there is an account structure with MainAccount-BusinessUnit-Department segments and an advanced rule with Project segment.
class TestLedgerDim
public static DimensionDynamicAccount generateLedgerDimension(
MainAccountNum _mainAccountId,
str _departmentId,
str _businessUnit,
str _projectId)
DimensionAttributeValueSetStorage dimensionAttributeValueSetStorage
= new DimensionAttributeValueSetStorage();
void addDimensionAttributeValue(
DimensionAttribute _dimensionAttribute,
str _dimValueStr)
DimensionAttributeValue dimensionAttributeValue;
if (_dimValueStr != '')
dimensionAttributeValue =
DimensionAttributeValue::findByDimensionAttributeAndValueNoError(
_dimValueStr);
if (dimensionAttributeValue.RecId != 0)
dimensionAttributeValueSetStorage.addItem(dimensionAttributeValue);
DimensionAttribute dimensionAttribute;
while select dimensionAttribute
where dimensionAttribute.ViewName == tableStr(DimAttributeOMDepartment)
|| dimensionAttribute.ViewName == tableStr(DimAttributeOMBusinessUnit)
|| dimensionAttribute.ViewName == tableStr(DimAttributeProjTable)
switch (dimensionAttribute.ViewName)
case tableStr(DimAttributeOMDepartment):
addDimensionAttributeValue(dimensionAttribute, _departmentId);
break;
case tableStr(DimAttributeOMBusinessUnit):
addDimensionAttributeValue(dimensionAttribute, _businessUnit);
break;
case tableStr(DimAttributeProjTable):
addDimensionAttributeValue(dimensionAttribute, _projectId);
break;
RecId defaultDimensionRecId = dimensionAttributeValueSetStorage.save();
return LedgerDimensionFacade::serviceCreateLedgerDimension(
LedgerDefaultAccountHelper::getDefaultAccountFromMainAccountRecId(
MainAccount::findByMainAccountId(_mainAccountId).RecId),
defaultDimensionRecId);
/// Runs the class with the specified arguments.
/// The specified arguments.
public static void main(Args _args)
// Prints 110110-001-022-000002
info(
DimensionAttributeValueCombination::find(
TestLedgerDim::generateLedgerDimension(
'110110',
'022',
'001',
'000002')).DisplayValue);
За это сообщение автора поблагодарили: trud (1).
ledgerdimension
ax_gfm_framework_team: Dimension defaulting in accounting distributions, Part 3 - Splitting and defaulting using Financial dimension default templates and Main account allocation rules Blog bot DAX Blogs 0 18.12.2013 09:11
dynamicsaxtraining: Vendor returns Blog bot DAX Blogs 0 11.10.2012 00:11
sumitsaxfactor: Ledger Accounts and Financial Dimensions Blog bot DAX Blogs 0 13.12.2011 22:11
Часовой пояс GMT +3, время: 01:28.
