Старый 11.04.2013, 14:55   #1
Question 1:
What happens if you compile these 3 commands and you are using the servicetier?
Object.”BLOB Reference”.EXPORT(‘c:xxy.txt’);
Object.”BLOB Reference”.EXPORT(‘c:xxy.txt’,FALSE);
Object.”BLOB Reference”.EXPORT(‘c:xxy.txt’,TRUE);
Answer 1:
You get this warning twice: “Function ‘EXPORT’ is obsolete for Microsoft Dynamics NAV Server.”
Question 2 (Surprised): Twice? Why not three times?
Answer 2: The first line (without the second parameter) does NOT generate the warning! And when running it on the servicetier, it works!
Question 3 (Even more surprised): I tried it and I don’t get ANY warning. Even worse. When I run it, I get “The EXPORT() method is obsolete.”
Answer 3: Question 1 and 2 were done on NAV2009R2 and now you are on NAV2013! But without the second parameter, it still works. But a warning would still be useful while compiling.
Читать дальше
Часовой пояс GMT +3, время: 10:52.
