Старый 29.01.2016, 02:19   #1
atinkerersnotebook: A Beginners Guide To Blogging and Social Media Promotion (Author Workshop Guide #3) Now Available
Источник: http://atinkerersnotebook.com/2016/0...now-available/
As you all might have noticed, I blog a lot, and I think that blogging is something that everyone should do, especially if you are on the front lines of a product or technology and you are learning something before others are. There is no point in hoarding information away from others because in the end the knowledge will pass away with you and be lost to the world. Also, by blogging and sharing with others you will find that you will start to be recognized more as an expert in your field regardless of how big or small it may be.
What you might not know about this though is that it really doesn’t consume that much of my time. If you make blogging a part of your everyday life, then you will find that it integrates in almost naturally into everything that you do and really won’t take much more time than what you were doing in the past. And also if there is something that you find that you need to note down in a blog for yourself to remember, then chances are pretty high that there are others out there that would like to know the answer. At the very least, you will start to build your own library of knowledge that you can reference back to.
Previously I showed some of you though my first Author Workshop how to quickly and almost mechanically create your content for your blogs and recently I sat down and documented the second half of this process which is the actual blogging process and also all of the different social media channels that I use while I am publishing my blogs. If you want to get some insight into my processes and how maybe you all can take advantage of them then maybe you might want to pick up a copy.
Here is a link to the guide: http://bit.ly/1PDHrrK
I have broken this guide down into two sections. The first will show you how easy it is to publish traditional blogs through one of my favorite blogging tools – WordPress, and in the second part we will look at some alternative blogging channels that you may want to take a look at and also how you can repurpose your content to be published as presentations and other media types.
Hopefully this along with the exercises that we have included in the guide will get you motivated to start blogging and sharing with your community.
Leon's CRM Musings: Is E-mail Dead And Is Communication Becoming Social? Blog bot Dynamics CRM: Blogs 0 25.06.2011 13:12
Часовой пояс GMT +3, время: 17:17.
