emeadaxsupport: Installing Reporting Services extensions on SQL Server 2014
Источник: http://blogs.msdn.com/b/axsupport/ar...rver-2014.aspx
============== Hello, When installing Reporting Services extensions on SQL Server 2014 you may run into this error: "Could not load file or assembly 'Microsoft.SqlServer.BatchParser, Version=10.0.0.0, Culture=neutral, PublicKeyToken=89845dcd8080cc91' or one of its dependencies. An operation is not legal in the current state. (Exception from HRESULT: 0x80131509)". To resolve this issue you should install the following components of SQL 2008 R2 Shared Management Objects:
Then, expand "Install Instructions" to see the download links. I hope this is helpful! Bertrand Источник: http://blogs.msdn.com/b/axsupport/ar...rver-2014.aspx
| Теги |
| ssrs |
