Старый 06.05.2015, 00:13   #1
emeadaxsupport: Cloning a developer machine that has a TFS workspace may result in an error
Источник: http://blogs.msdn.com/b/axsupport/ar...-an-error.aspx
Setting up a developer box VM and cloning it for other developers is a great way to spin up machines quickly. However if you have already connected to a TFS workspace your machines may throw an error regarding the workspace when logging on a different user and opening the client for the first time.
The TFS workspace files are cached on the client machine in the following directory.
%userprofile%\appdata\local\microsoft\team foundation\3.0\cache
The file you'll need to modify will be the VersonControl.config file.
You can rename this file to VersionControl-old.config and re-launch the AX client, this will rebuild the config file with the appropriate workspace associated to the current user.
emeadaxsupport: Adding a item to the AX R3 Online Store gives the error message "We cannot Process your request at this time. Please try again later. " Blog bot DAX Blogs 0 27.11.2014 02:34
emeadaxsupport: Connecting Retail Components on an External Computer to the Microsoft Dynamics AX R3 Azure Lifecycle Services Demo Virtual Machine Blog bot DAX Blogs 0 28.06.2014 00:13
emeadaxsupport: Kerberos Authentication Error Code: 0x7 KDC_ERR_S_PRINCIPAL_UNKNOWN Extended Error: 0xc0000035 KLIN(0) Blog bot DAX Blogs 0 09.11.2010 19:10
emeadaxsupport: Error "Unable to render content due to an error" when editing Timesheet Blog bot DAX Blogs 0 06.08.2010 17:05
Часовой пояс GMT +3, время: 21:08.
