Старый 10.04.2013, 17:11   #1
emeadaxsupport: Changes have been made to combination "" since the combination was last used -The combination must be re-validated to be used.
Источник: http://blogs.msdn.com/b/axsupport/ar...o-be-used.aspx
If you run into an error message 'Changes have been made to combination "" since the combination was last used - The combination must be re-validated to be used' or "Account Structure " ", for the combinationis not valid for chart of accounts " "
try to check the following
1. Go to DataDictionary\Tables\DimensionAttributeValueCombination
2. Try to find the account mentioned in the error log, in this case '211100--' as stored in the 'DisplayValue' field. Take a note of the field 'AccountStructure' and do a lookup and you can see that the account structure associated is '5637144865 DEPT'
3. Take a note of this accountructure name and the issued chart of account in the error message. The same can be seen by going to GeneralLedger\Setup\Ledger and noting the linked Chart of account. Here ‘Corporate Main Account (Shared)
Notice if these accountstructures are the same as identified in the table ‘DimensionAttributeValueCombination’ eg. we search for account ‘211100’ and notice that the account structures linked here is 'Account Structure' as the '211100' is a balance account
However, what we saw in the table ‘DimensionAttributeValueCombination’ the link in this table(DimensionAttributeValueCombination) is to the account structure was ‘DEPT’. This is out of sync with the one defined for the chart of accounts,
hence why are getting the error. The solution is therefor to change the linked accountstructure in ‘DimensionAttributeValueCombination’ from 'DEPT' to 'Account Structure' as defined in the Chart of account setup and the posting can go through
Try to see now if the posting is possible
Note, if you are unsure of which record to locate in the DimensionAttributeValueCombination table note that the link to this table is done by the value parsed from (table) GeneralJournalAccountEntry.LedgerDimension. You can put in a breakpoint on Class\LedgerVoucherTransObjectCheck\Check around line 111 or insert a temporary print screen statement as on the screenshot below. Take a note of the RecID issued and then search for this in the DimensionAttributeValueCombination table- you should see the posting and offset account references being printed
emeadaxsupport: Adding a period to the Aging Period Definition and receive the error: "Unlimited can be used only in the first and last period" or "Unit must be less than 0" Blog bot DAX Blogs 0 29.03.2013 06:11
emeadaxsupport: "An exchange rate cannot be found for exchange rate type XXX between currencies YYY and ZZZ on exchange date." when you attempt to process in Microsoft Dynamics AX 2012 Blog bot DAX Blogs 0 26.09.2012 07:15
emeadaxsupport: What to do if you have a crash Blog bot DAX Blogs 0 15.06.2011 18:11
emeadaxsupport: Running AX 2009 Client raises error: "An invalid directory structure for Microsoft Dynamics AX was detected" Blog bot DAX Blogs 0 01.04.2011 06:13
emeadaxsupport: Error "Unable to render content due to an error" when editing Timesheet Blog bot DAX Blogs 0 06.08.2010 17:05
Часовой пояс GMT +3, время: 09:09.
