Старый 12.06.2012, 12:11   #1
ax-erp: X++ Code to get the Ranges / Criteria from Query
Источник: http://microsoft-dynamics-ax-erp.blo...eria-from.html
Hi ,
Following Job illustrates how we can get the criteria / ranges specified by the user in the run-time Query criteria dialog.
static void Query_getRanges(Args _args)
    Query                   query = new Query();
    QueryRun                queryRun;
    QueryBuildDataSource    qbd;
    CustTable               custTable;
    QueryBuildRange         range;
    int                     cnt, i;
    qbd = query.addDataSource(tablenum(CustTable));
    queryRun = new QueryRun(query);
    queryRun.prompt();   // To Prompt the dialog
    cnt = queryRun.query().dataSourceTable(tablenum(CustTable)).rangeCount();
    for (i=1 ; i<=cnt; i++)
        range = queryRun.query().dataSourceTable(tablenum(CustTable)).range(i);
        info(strfmt("Range Field %1, Value %2",range.AOTname(),range.value()));
    while (queryRun.next())
        custTable = queryRun.get(tablenum(CustTable));
        info(strfmt("Customer %1, Name %2",custTable.AccountNum, custTable.Name));
Enjoyyy !!!!
Последний раз редактировалось Poleax; 13.06.2012 в 14:08.
X++: When to use Managed Code in Dynamics AX Blog bot DAX Blogs 0 08.12.2011 10:11
dynamics-ax: Microsoft Highlights New ERP Public Sector Capabilities for AX 2012 Blog bot DAX Blogs 0 23.05.2011 19:11
emeadaxsupport: Debugging non-interactive X++ code in Dynamics AX 2009 when running on Windows Server 2008 Blog bot DAX Blogs 0 23.09.2009 13:05
Часовой пояс GMT +3, время: 19:50.
