Rahul Sharma: Change File Ownership through X++ in Dynamics AX
Источник: http://feedproxy.google.com/~r/Rahul...ough-x-in.html
============== This article shows a little trick that might be needed for testing AX AIF file adapter based integration. We all know that how frustrating it can be to setup input file ownership to current AX user while testing otherwise AX will complain about it. Here is a small static function with filepath as a parameter. This function will set current AX user as the owner of the input file. This function can be called right before the call to fileSystem.ReadFile(filePath) in \Classes\AifFileSystemReceiveAdapter\readFile. X++: 1: static client protected void SetFileOwnership2CurUser(FilePath _filePath) 2: { 3: UserInfo userInfo; 4: System.IO.FileInfo fileInfo; 5: System.Security.AccessControl.FileSecurity fileSecurity; 6: System.Security.Principal.SecurityIdentifier sid; 7: System.Security.AccessControl.AccessControlSections acSections; 8: ; 9: 10: //select current user 11: select userInfo 12: where userInfo.Id == curuserid(); 13: 14: try 15: { 16: new InteropPermission(InteropKind::ClrInterop).assert(); 17: fileInfo = new System.IO.FileInfo(_filePath); 18: acSections = System.Security.AccessControl.AccessControlSections::Owner; 19: fileSecurity = fileInfo.GetAccessControl(acSections); 20: sid = new System.Security.Principal.SecurityIdentifier(userInfo.sid); 21: //set ownership 22: fileSecurity.SetOwner(sid); 23: fileInfo.SetAccessControl(fileSecurity); 24: CodeAccessPermission::revertAssert(); 25: } 26: catch 27: { 28: throw error(AifUtil::getClrErrorMessage()); 29: } 30: } Последний раз редактировалось Poleax; 07.06.2011 в 14:31. Причина: оформление |
