workflowax: No .NET Business connector session found.
Источник: http://workflowax.wordpress.com/2010...session-found/
============== My quick fix for the day. If you are getting an error message “No .NET Business connector session found.” in your system event log, there may be a number of things to look at, however the first thing to check is whether the default business connector on your IIS machine is set up and pointing to the correct AOS. This may occur on development servers with multiple AOS instances. You can take a look at this post how to setup multiple workflow websites on the same machine in order to avoid this issue. Happy Daxing ![]() Источник: http://workflowax.wordpress.com/2010...session-found/
