d365technext: D365FO Batch Job retries
Источник: http://d365technext.blogspot.com/202...b-retries.html
============== Enable automatic retries on batch jobs In the April/May released, Microsoft introduces the feature to retry the batch job, In the past, if the Finance and Operations apps experience any kind of loss of connection to Microsoft SQL Server, then all batch jobs that are running fail, and the reason is, on Azure if the connection is lost then the recovery is almost impossible. So, Microsoft introduces an Interface class that will batch to reset itself in case of connection loss or failure. How you can implement it in your code? Here is an example if you are using the "RunBaseBatch" class in your batch Job. class TestBatchJob extends RunBaseBatch implements BatchRetryable { [Wrappable(true), Replaceable(true)] // Change to meet your customizability requirements public boolean isRetryable() // Use final if you want to prevent overriding { return true; } } Here is an example if you are using the "SysOperationServiceController" class in your batch Job. class TestBatchJob extends SysOperationServiceController implements BatchRetryable { [Wrappable(true), Replaceable(true)] // Change to meet your customizability requirements public boolean isRetryable() // Use final if you want to prevent overriding { return true; } } Important If you designing a multithreading job and adding the runtime task, then you should implement this interface on both the main controller and the task controller. If you want to disable the retry of the batch job then add your class in the Batch class configuration overrides Overrides setup Источник: http://d365technext.blogspot.com/202...b-retries.html
Опции просмотра | |
