Старый 25.08.2021, 23:18   #1
powerobjects: How to Set Up a More Solution-friendly On-demand Power Automate Cloud Flow
Источник: https://powerobjects.com/flow/how-to...te-cloud-flow/
With Power Automate combined with Dynamics 365 CE, there currently is a way to set up an on-demand Cloud Flow to run from the ribbon bar: select Flow > Create a flow and then add your business logic. However, there is one glaring issue with using this method that makes it problematic. The connector that this feature uses is the Dataverse Legacy connector. This Legacy connector is not solution...
Source
powerobjects: Bridging Logic with IFTTT and Flow Blog bot Dynamics CRM: Blogs 0 22.12.2018 05:41
dynamicsaxse: November 2018 Release – Dynamics AX2012 R3 update Blog bot DAX Blogs 0 15.11.2018 09:11
powerobjects: Empowering Your Team with Microsoft Flow Blog bot Dynamics CRM: Blogs 0 06.09.2018 02:35
powerobjects: Field Service Mobile App: Set up and Configuration for Dynamics 365 Online Blog bot Dynamics CRM: Blogs 0 16.01.2018 01:12
atinkerersnotebook: Creating New Customer Notifications for Dynamics 365 for Operations using Flow and the Common Data Service Blog bot DAX Blogs 0 15.12.2016 22:12
Часовой пояс GMT +3, время: 15:38.
