Старый 27.08.2021, 00:48   #1
d365technext: Access Fields In A Table Using This Field Id
Источник: http://d365technext.blogspot.com/202...his-field.html
How To Access Field In A Table Using This Field Id
To do this you could use the next construction:
vendTable.( filednum( vendTable, VendAccount ) ) = “XXX”;
This is the same as
vendTable.VendAccount = “XXX”;
Example:
Field VendAccount from VendTable has id 1. Then statement VendTable.(1) = “V-00014” – will initialize field VendAccount with value “V-00014”.
You could also use this feature while working with records of type Common.
Example:
Common common;
VendTable vendTable;
select vendTablewhere vendTable.VendAccount== "V-00014";
common = vendTable;
info( common.( fieldnum( vendTable, VATNum) ) );
saurav-nav: NAV 2018 - Lots of New Objects! Blog bot NAV: Blogs 0 04.12.2017 10:11
german_nav_developer: Upgrade Tips & Tricks Teil 3 Blog bot NAV: Blogs 0 17.03.2017 13:11
CRM DE LA CREME! Some more useful javascripts for MS CRM Blog bot Dynamics CRM: Blogs 0 04.05.2010 11:05
wiki.dynamicsbook: Changes Made in Navision Attain 3.01B Blog bot Dynamics CRM: Blogs 0 21.08.2008 20:43
Часовой пояс GMT +3, время: 11:49.
