d365technext: Access Fields In A Table Using This Field Id
Источник: http://d365technext.blogspot.com/202...his-field.html
============== How To Access Field In A Table Using This Field Id To do this you could use the next construction: vendTable.( filednum( vendTable, VendAccount ) ) = “XXX”; This is the same as vendTable.VendAccount = “XXX”; Example: Field VendAccount from VendTable has id 1. Then statement VendTable.(1) = “V-00014” – will initialize field VendAccount with value “V-00014”. You could also use this feature while working with records of type Common. Example: Common common; VendTable vendTable; ; select vendTablewhere vendTable.VendAccount== "V-00014"; common = vendTable; info( common.( fieldnum( vendTable, VATNum) ) ); Источник: http://d365technext.blogspot.com/202...his-field.html
Опции просмотра | |
