Старый 04.05.2012, 14:11   #1
workflowax: Stopped (error): Failed to find workflow instance. Failed to find workflow instance.
Источник: http://workflowax.wordpress.com/2012...ow-instance-5/
We recently recently came across an issue at a client site where workflows instances would be completed but the status would be “Stopped (error)” with error messages saying “Failed to find workflow instance. Failed to find workflow instance. Failed to find workflow instance. Failed to find workflow instance” after investigating the issue for quite a while and not finding a solution I eventually found a post at “Peng’s Dynamics AX“ Blog where he listed a hotfix that Microsoft released to resolve this bug. The knowledge base article for KB2398999 and download link can be found at: http://support.microsoft.com/hotfix/...s&sd=mbs#step2
Thanks to Peng for reporting this issue to Microsoft and following up with them for a year! You can view the original blog post here.
Старый 06.08.2020, 16:22   #2
Aleks_K is offline
Aleks_K
MCTS
Сотрудник Innoware
48 / 13 (1) ++
Приветствую. К сожалению MS прекратил доступ к обновлению KB2398999.
Может у кого-то завалялось? Или подскажете где поискать? Очень надо.
Спасибо.
workflowax: Microsoft Dynamics AX 2012 Workflow error: “Failed to find workflow version” Blog bot DAX Blogs 0 13.03.2012 18:11
workflowax: Workflow history error – Stopped (error): Could not find user Blog bot DAX Blogs 0 11.02.2012 01:11
emeadaxsupport: Microsoft Dynamics AX 2012 Workflow error: “Failed to find workflow version” Blog bot DAX Blogs 0 25.10.2011 20:11
workflowax: What is a workflow owner used for? Blog bot DAX Blogs 0 01.06.2010 15:05
Ошибка бизнес-процесса Tarasov E Dynamics CRM: Разработка 9 18.02.2010 14:02
Часовой пояс GMT +3, время: 12:30.
