Старый 18.04.2020, 09:15   #1
ievgensaxblog: MSDyn365FO. Add Licenses to Deployable Package during release
Источник: https://ievgensaxblog.wordpress.com/...uring-release/
Recently, one of the environments I’m working with has been updated to self-service and I cannot install ISV license via deployable package anymore. Luckily there is “Add Licenses to Deployable Package” DevOps task available.
You can use it either in build or release pipeline. I prefer not to touch build and leave it standard, so below I will show one of the ways how to use it in your release pipeline.
First, add license file to a version control. I’m dealing with multiple ISVs, so I created folder “Licenses” under Trunk\Main and added all the licenses there.
Now we need to make those files available for the release pipeline. Under Artifacts you can add another one, select “TFVC”, Set Project and Source
Next step is to add new task
Here in search pattern I’m picking all the txt files from “Licenses” folder, so when I get new license all I need is to check it in and rerun a release without even running a full build.
ievgensaxblog: MSDyn365FO. How-to extend product dimension lookup to add dimension description. Blog bot DAX Blogs 12 01.07.2019 12:13
ievgensaxblog: MSDyn365FO. How to Import CSV file using Electronic Reporting. Part 2 – Format. Blog bot DAX Blogs 0 06.02.2019 07:12
ievgensaxblog: MSDyn365FO. Add postTargetProcess method to a Data Entity via extension. Blog bot DAX: База знаний и проекты 0 25.01.2019 15:11
alexef: How to add a field to Item Card in Business Central Blog bot NAV: Blogs 0 22.05.2018 20:11
Van Vugt: On NAV 2013 Licenses - Part 2 | Add-on Ranges Blog bot Dynamics CRM: Blogs 0 18.10.2012 23:02
Часовой пояс GMT +3, время: 23:11.
