crmtipoftheday: Tip #1311: Use entity name in Flow lookups
Источник: https://crmtipoftheday.com/1311/use-...-flow-lookups/
============== If you are building your Flows from solutions and connecting to Common Data Service, you should use the CDS (current environment) connector. When you do, if you populate lookup fields, you might get a “resource not found” error message. ![]() ![]() Cover photo by unsplash-logoWesley Pribadi Источник: https://crmtipoftheday.com/1311/use-...-flow-lookups/
