How to debug Workflow in D365 without access to Batch.exe
Источник: http://alexvoy.blogspot.com/2019/08/...5-without.html
============== Correct me if I am wrong, but there is no specific article https://docs.microsoft.com about debugging custom Workflow in D365. So, once I bumped into necessity to test my custom Workflow classes, I found myself unlucky not having admin rights fot Batch.exe (as described here https://ax.docentric.com/debug-workf...nd-operations/) Next search results (in particular this one https://thwidmer.wordpress.com/categ...x-2012/page/2/) brought me to the following steps. I stopped DynamicsAxBatch, which execute actual batch processing in D365. I added the following simple class and and a menu item button to a form. class CDPWFDebuggerActive { static public void main(Args _args) { SysWorkflowMessageQueueManager::runStatic(conNull()); } } Now I run it by the button to execute batch processing in step-by-step mode, and it perfectly hits my breakpoints inside of Workflow handlers once I attached to the standard IIS process. Источник: http://alexvoy.blogspot.com/2019/08/...5-without.html
