Старый 01.04.2019, 10:11   #1
dynamicsnavax: Embed PowerApp in Modern POS
Источник: http://dynamicsnavax.blogspot.com/20...odern-pos.html
There was a feature released around 8.1.3 to open URL in POS.
https://docs.microsoft.com/en-us/dynamics365/unified-operations/retail/open-url-in-pos
Follow the guide to add a button to POS via the Screen Layouts. In the Action, select Open URL.
Enter the PowerApps url. In this case I want it to open up as embedded rather than popping up with a new window.
Run your distribution job to have it show up on POS.
Below is an example I am working on. We have an external system managing licensing.
Just note, that it will pop up with a Microsoft login screen. You can tick the login to remember you.
If the screen doesn’t fit in the POS window. You can click on “Fit to screen” on the top right.
Hope this gives you ideas to take advantage of in Retail space. Possibilities are endless.
dynamicsnavax: Debug POS using .NET Reflector Blog bot DAX Blogs 0 30.10.2018 20:11
Sumit Potbhare: Modern POS installation on Windows Laptop | D365 for Retail Blog bot DAX Blogs 0 24.10.2018 12:11
dynamicsnavax: Using Global Variables with Retail Modern POS Blog bot DAX Blogs 0 14.08.2018 16:11
emeadaxsupport: AX for Retail: Modern POS Custom Labels and Strings Blog bot DAX Blogs 0 24.05.2017 23:13
axsa: How to connect Modern POS to Dynamics AX 2012 R3 CU8 instance in Azure Blog bot DAX Blogs 0 07.02.2015 12:11
Часовой пояс GMT +3, время: 03:23.
