Старый 05.12.2018, 15:11   #1
mfp: Chain of command on forms
Источник: https://blogs.msdn.microsoft.com/mfp...mand-on-forms/
Chain of command now supports even more extension scenarios on forms. It is now possible to wrap: Methods on the root of the form. Methods on controls. Methods on data sources. Methods on fields on data sources. So far you can only wrap system methods on the latter 3, i.e. methods that are defined on...
chain of command, d365fo, extensions
sertandev: AX7 (D365) Chain of command with example Blog bot DAX Blogs 0 20.03.2018 13:11
mfp: Extensible X++: Chain of Command Blog bot DAX Blogs 43 12.07.2017 01:17
mfp: What is new in X++ in AX7? Blog bot DAX Blogs 2 10.02.2016 00:29
mfp: X++ in AX7: Forms implementing interface Blog bot DAX Blogs 0 20.12.2015 09:16
Microsoft Dynamics CRM Team Blog: Read-optimized forms Blog bot Dynamics CRM: Blogs 0 23.03.2012 04:25
Часовой пояс GMT +3, время: 02:37.
