Старый 12.07.2018, 17:12   #1
crmtipoftheday: Tip #1132: Performance of various instance types
Источник: https://crmtipoftheday.com/1132/perf...nstance-types/
We keep hearing this question over and over again from the customers, consultants, and developers:
Are production instances given any preferential treatment in terms of resources as compared to sandbox and trial instances?
I thought it’d be a good idea to revisit the 4 years old answer as nothing has changed since then. As per the original post by the Dynamics 365 Customer Engagement Team that welcomed sandbox instances to the world:
We don’t treat the running Sandbox applications any differently from Production instances.  They are both given the same level of resources and support.
There are some differences in terms of what operations are available, i.e. what you can do with your instance. For example, you can delete the sandbox but not production, and you can convert trial to a paid instance but not reset it. But, as far as performance is concerned it’s all the same infrastructure, scale groups, resources; same everything.
It’s worth mentioning that the performance of various instances may vary but it’s a combination of your proximity to the data center, your scale group neighbours, time of the day, moon phase, humidity in Cleveland, OH, and Mars position relative to the Orion’s belt. On other words, if you see the same operation taking longer in one of the otherwise identical instances, most likely you forgot to bring your gifts to the ancient Nordic god Randomizer.
Facebook and Twitter cover photo by dylan nolte on Unsplash
crmtipoftheday: Tip #1077: Connect to the right instance Blog bot Dynamics CRM: Blogs 0 16.02.2018 11:11
crmtipoftheday: Tip #1060: Quickly create vector/SVG images for Dynamics 365 Blog bot Dynamics CRM: Blogs 0 24.01.2018 22:11
ошибка в AIF syl DAX: Программирование 14 20.08.2015 15:25
emeadaxsupport: Managing general performance issues in Microsoft Dynamics AX Blog bot DAX Blogs 0 12.09.2014 12:11
emeadaxsupport: AX Performance Troubleshooting Checklist Part 2 Blog bot DAX Blogs 0 09.09.2014 16:11
Часовой пояс GMT +3, время: 06:28.
