Старый 06.06.2018, 15:11   #1
gustafwesterlund: Setting up Data Export Service without PowerShell Script
Источник: http://gustafwesterlund.blogspot.com...e-without.html
Setting up Dynamics 365 Data Export Service requires a Azure KeyVault to be set up which is typically done using a PowerShell script which can be found in the Data Export Service setup wizard. However, if you run into issues setting this up, it might be easier to do this directly in Azure by minimizing the steps of the scripts. This was a tip that my friend and Business Solution MVP Scott Durow recommended. He mentions this in his very instructive video, but doesn't actually show how, so I thought I'd just detail how I made it work.
First some background. The reason why I even started investigating how to do this manually was that when I tried running the PowerShell script supplied by Microsoft in the wizard.
Press the "i" icon to get a window containing the PowerShell Script that Microsoft recommends for setting up the Key Vault.When running the PowerShell script both as myself (not a global admin) and asking a global admin to do it, it failed in the latter parts. The key vault was created by some of the access policies seemed to be missing and it just didn't work. My users rights in Azure was Contributor in the Resource Group, and it was a bit interesting cause the global admin and I got different error messages, but when I finally managed to create the key vault manually, I could do it all with my user, so it didn't seem I was missing any rights to do it.
First step is to make sure you have all your data straight. The power shell script is good for this. Check out Scott clip if you want to know how to find the different strings. He shows it very clearly.
Just copied from the PS-Script:
$subscriptionId = ''
$keyvaultName = 'MyVault'
$secretName = 'MySecretName'
$location = 'North Europe'
$connectionString = 'Server=tcp:,1433;Initial Catalog=;Persist Security Info=False;User ID={your_username};Password={your_password};MultipleActiveResultSets=False;Encrypt=True;TrustServerCertificate=False;Connection Timeout=30;'$organizationIdList = '' $tenantId = ''
The highlighted parts have to be replaced by your settings. I will use these variables to have something to reference to further in this article.
Search for Key Vault and add the "Key vault", the top one in this picture
Then we have to set it up. Not so tricky if you have worked with Azure before. Consider if you want to work in an existing Resourcegroup or if you want to create a new one. Typically you need to have Azure SQL services running as well so it might be good to keep them all together to be able to see the costs and control who has access why a resource group might be a good idea. But that should hence already exist. If not, you can create it. I would recommend keeping Azure SQL and Key vault in the same, not sure if it actually works in different resource groups, probably does, but I haven't tested.
Creating the key vault - in this case I am creating a new resource group, normally it would already existAzure will add you as the default principal with access to the key vault. We will add Data Export Service to this later. For now, just create it.
Now we need to open the Key vault and select the "Secrets" section in the menu on the left hand side and press the button:
"+ Generate/Import"
Then you have to enter you Secret name ($secretName) and the connection string ($connectionString) into the value.
Creating a secret - $secretname in Name and $connectionstring in Value
Press "Create".
You should now return to the previous screen and see a row for your secret.
Select it.
It should open the settings panel for the Secret, press the "Tags" part which is located in the middle and add a tag which has $OrgIdList ($organizationIdList) as the key and Tennant ($tenantId) as value. I have blurred them out below as they are rather private.
Adding a tag with OrgIdList and tenantId to a Secret
You then need to go back to the Key Vault and click on the "Access Policies" menu item, you should then see yourself as the principal as this was set when we created the key vault. We now need to add Data Export Service as a valid Principal with read access rights.
So click "Add", click "Select Principal" and search for "b861dbcc-a7ef-4219-a005-0e4de4ea7dcf" which is the ID for Data Export Service. It should show up like this:
It needs to have "Secret Management Operations - GET" permissions and nothing else.
Now, go back to the Secret and copy the URI to the Secret.
Getting the URI for the Key Vault SecretPaste it into the Data Export Service Wizard field for Key Vault.
Fill in the other information and press validate. Hopefully it will work out well!
Some issues
Being too cheap with the Azure SQL level
If you don't go for a Azure SQL P1 and choose a lower tier, you might get this warning:
We tried an S0 for our Dev environment and tried to sync a couple of million records and that just didn't work, we got tons of errors. We upgraded the ASQL to S2 and then at least we didn't get any errors. We are planning for P1s in UAT and production.
Might have to set activation date on secret
Seems that you might have to set an activation date on the secret. Not sure why this is, the PS-script doesn't seem to do this. But not very hard.
Added activation date on the Secret from June 4.th
Using Database schema that is not created
The default database schema is "dbo" in the Data Export Service Wizard. If you change this to something else like "crm" and you haven't created this in the database, you will get an error. It is simple to fix, you just have to go into the database and create the schema. To create the schema "crm" open a query and run:
CREATE SCHEMA crm
For more information on how to create schemas, check this site: https://docs.microsoft.com/en-us/sql...ql-server-2017
Once the schema has been created, there should be no problem using it, as long as the user has permissions using it.
I hope this works for you. If you have any questions, don't hesitate to leave a comment.
Gustaf Westerlund
MVP, Founder and Principal Consultant at CRM-konsulterna AB
www.crmkonsulterna.se
emeadaxsupport: SEPA affected objects Blog bot DAX Blogs 0 29.11.2013 13:11
NAV Team: How to: Enable Import/Export of Bank or Payroll Files Using the Data Exchange Framework Blog bot Dynamics CRM: Blogs 0 18.10.2013 02:33
atinkerersnotebook: Using Service Management to Track Service Orders Blog bot DAX Blogs 1 25.08.2013 19:16
Часовой пояс GMT +3, время: 16:51.
