Старый 05.02.2018, 20:13   #1
crmtipoftheday: Tip #1068: How to Grant Access to Organization Insights
Источник: https://crmtipoftheday.com/1068/how-...tion-insights/
Back in my first TOTD post, I sung the benefits of Organization Insights. It is truly the administrator’s best friend. But what if a non-administrator wants in on the action? It turns out that, by default, the only two Security Roles that can see the Organization Insights dashboard are the System Administrator and System Customizer roles. For others to see the dashboard, we must either give them one of these two roles (probably unwise) or tweak the role they have.
In this case the role tweak resides in a custom entity called ‘OrgInsights User Dashboard Definition’ which is in the ‘Custom Entities’ of the Security Role you want to adjust. Also remember that, depending on the graphic being shown, the Security Role may also need additional privileges to access the underlying data.
crmtipoftheday: Tip #1065: How to get clean Customer Service trial Blog bot Dynamics CRM: Blogs 0 31.01.2018 07:18
crmtipoftheday: Tip #1039: Give your customers access to e-learning Blog bot Dynamics CRM: Blogs 0 08.12.2017 10:51
crmtipoftheday: Tip #1036: Organization Insights Is The Administrator’s Best Friend Blog bot Dynamics CRM: Blogs 0 04.12.2017 03:51
crmtipoftheday: Tip #1014: How to target delegated administrator in apps Blog bot Dynamics CRM: Blogs 0 01.11.2017 16:11
Часовой пояс GMT +3, время: 15:53.
