Старый 29.10.2017, 13:11   #1
sinedax: Setup the AOS Balancing on AIF WEB Services or WHS Mobile Portal - AX 2012
Источник: http://sinedax.blogspot.com/2017/10/...-services.html
Hi Guys
In an AX Environment with a huge AX Services workload, it is suggested to enable the AX Services Balance.
In order to do that, you have to:
  • First, enable the NLB or ILB
    if you are working in Azure
  • If you want enable the Balance through:
    • AIF Web Services
    • Remote Desktop Host Server
    • SSRS Services
    • Management Reporter
      You have to follow the standard link High Availability best practices for Dynamics AX 2012 in order to setup the Balance through the Dynamics AX Configuration Utility.
      You have to do that on each Servers listed above.
      Practically you have to:
    • Through the Dynamics AX Configuration Utility create a new Configuration on “Local Client” and on “Business Connector” Target. You can named it “Balance”
    • On both Configurations, in the Connection Tab fill “Server Name” with the IP or Name of the Balance
    • Through the Registry (HKEY_CURRENT_USER and HKEY_LOCAL_MACHINE) at the path “\Software\Microsoft\Dynamics\6.0\Configuration\new_configuration_name” create two key “wcflbservername” and “wcflbwsdlport” and fill them respectively with the Balance IP or name and the Wsdl Port
      “new_configuration_name” will be the new AX Configuration created
    • Come back to the AX Configuration Utility and refresh both configurations with the “Refresh Configuration” button
  • If you are using the WHS Mobile Portal, modify the “Web.config” file that usually is store at “C:\Dynamics60\Warehouse Mobile Devices Portal\00” and modify the endpoint with your “Balance” IP or Name:
Talking about AIF Web Services or WHS Mobile Portal, in some cases, you have to create also an IIS Farm in order to balance the IIS Connections. If you are working on Azure you have to use the Azure Application Gateway in order to do that.
Till Soon!
ax2012, load balancing
DAX: Microsoft Dynamics AX 2012 R3 is now available! Blog bot DAX Blogs 1 02.05.2014 23:00
kamalblogs: AIF: Testing Document services surpassing the AIF setup – Dynamics AX 2012 Blog bot DAX Blogs 0 05.11.2013 21:11
Hotfix 2845539 is available to provide an AIF Windows Azure Service Bus Adapter for services in Microsoft Dynamics AX 2012 R2 Vadik DAX: База знаний и проекты 0 31.05.2013 11:11
Часовой пояс GMT +3, время: 11:02.
