stephenmann: AX 2012 AOS not starting after CU12 update
Источник: https://www.stephenmann.net/single-p...er-CU12-update
============== Some people may be experiencing their AOS not starting after applying the CU12 kernel update. Exception code: 0xe0434352 Faulting application path: C:\Program Files\Microsoft Dynamics AX\60\Server\MicrosoftDynamicsAx\Bin\Ax32Serv.exe Faulting module path: C:\Windows\system32\KERNELBASE.dll The exception code refers to a .NET runtime exception. Â You should find that installing .NET framework 4.6 will resolve this issue. Â The installer does not check this as a prerequisite. .net Framework 4.6 web installer is available here: https://www.microsoft.com/en-au/down....aspx?id=48130 Источник: https://www.stephenmann.net/single-p...er-CU12-update
