Старый 16.08.2013, 11:47   #1
zipo is offline
zipo
AOS Cannot load assemblies - AX2012 R2
Господа подскажите что это за ошибки и как с ними бороться?
При старте АОС в Windows Application Log добавляются такие записи с типом Information:
Object Server 01: Could not load assembly 'Microsoft.Dynamics.Retail.MatrixPivotGrid, Version=6.2.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35' or one of its dependencies.
Object Server 01: Could not load assembly 'Microsoft.Dynamics.AX.Framework.Analytics, Version=6.2.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35' or one of its dependencies.
Object Server 01: Could not load assembly 'Microsoft.Dynamics.AX.Framework.Client.Controls, Version=6.2.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35' or one of its dependencies.
Object Server 01: Could not load assembly 'Microsoft.Dynamics.AX.Frameworks.ProductConfiguration, Version=6.2.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35' or one of its dependencies.
Object Server 01: Could not load assembly 'Microsoft.Dynamics.Kernel.Client, Version=6.2.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35' or one of its dependencies.
Object Server 01: Could not load assembly 'Microsoft.Dynamics.AX.Framework.Workflow.Metadata.Wizard, Version=6.2.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35' or one of its dependencies.
Object Server 01: Could not load assembly 'Microsoft.Dynamics.AX.Framework.Workflow.Model.Design, Version=6.2.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35' or one of its dependencies.
Object Server 01: Could not load assembly 'Microsoft.Dynamics.Retail.StoreConnect.MessageTreeControl, Version=6.2.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35' or one of its dependencies.
Object Server 01: Could not load assembly 'RetailControls, Version=5.3.0.0, Culture=neutral, PublicKeyToken=null' or one of its dependencies.
Object Server 01: Could not load assembly 'Microsoft.Dynamics.Retail.StoreConnect.TransAutomClient, Version=0.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35, processorArchitecture=x86' or one of its dependencies.
Could not load assembly 'EInvoiceCFDI_MX.dll.config' or one of its dependencies.
Object Server 01: Could not load assembly 'ElectronicFiscalDocument_BR.dll.config' or one of its dependencies.
ДЛЛки эти вроде как клиентские и почему их АОС вообще пытается загрузить загадка.
Старый 03.09.2013, 17:44   #2
ice is offline
ice
Аватар для ice
1,822 / 402 (17) +++++++
up
Старый 04.09.2013, 12:22   #3
ice is offline
ice
Аватар для ice
установка SQL AMO решило проблему
За это сообщение автора поблагодарили: AlGol (3), Logger (3).
Старый 30.03.2017, 11:11   #4
AlGol is offline
AlGol
277 / 93 (4) ++++
Большое спасибо, это единственный пост где я нашел упоминание об AMO для того, чтобы заставить работать dll Microsoft.Dynamics.AX.Framework.Analytics.
Везде написано только об установке SMO, но это не помогало.
Общий комплект пакетов которые заставили работать форму Серверы Анализа на терминальном сервере где запускался клиент AX2012R2 получился такой:
Ален ноби, ностра алис.
Что означает - если один человек построил, другой завсегда разобрать может.
За это сообщение автора поблагодарили: Logger (5).
Ax2012 R2 update The aos cannot be reached nano3 DAX: Администрирование 7 01.03.2013 10:56
ukax: Dynamics AX2012 R2 Launches!!!! Blog bot DAX Blogs 0 04.12.2012 19:11
axinthefield: Are your AX 2012 AOS servers load balancing? Blog bot DAX Blogs 0 02.05.2012 13:11
emeadaxsupport: AX2012 and AX2009 or AX4 side by side - AOS performance counters overwritten Blog bot DAX Blogs 0 13.03.2012 18:11
axinthefield: AOS Load Balancing Blog bot DAX Blogs 0 20.01.2012 23:13
Часовой пояс GMT +3, время: 12:32.
