New page
The hosts file and the services file are used (in place of [[DHCP]]) to redirect connections to a specific TCP/IP address on the network. The files are located in C:WINDOWSsystem32driversetc they do not have extensions. ==Use in Dynamics NAV== ==hosts== The default hosts file in windows will look something like: # Copyright © 1993-1999 Microsoft Corp. # # This is a sample HOSTS file used by Microsoft TCP/IP for Windows. # # This file contains the mappings of IP addresses to host names. Each # entry should be kept on an individual line. The IP address should # be placed in the first column followed by the corresponding host name. # The IP address and the host name should be separated by at least one # space. # # Additionally, comments (such as these) may be inserted on individual # lines or following the machine name denoted by a '#' symbol. # # For example: # # 102.54.94.97 rhino.acme.com # source server # 38.25.63.10 x.acme.com # x client host 127.0.0.1 localhost ==services== The default services file in windows will look something like: # Copyright © 1993-1999 Microsoft Corp. # # This file contains port numbers for well-known services defined by IANA # # Format: # # <service name> <port number>/<protocol> [aliases...] [#<comment>] # echo 7/tcp echo 7/udp discard 9/tcp sink null discard 9/udp sink null systat 11/tcp users #Active users systat 11/tcp users #Active users daytime 13/tcp daytime 13/udp qotd 17/tcp quote #Quote of the day qotd 17/udp quote #Quote of the day chargen 19/tcp ttytst source #Character generator chargen 19/udp ttytst source #Character generator ftp-data 20/tcp #FTP, data ftp 21/tcp #FTP. control telnet 23/tcp smtp 25/tcp mail #Simple Mail Transfer Protocol time 37/tcp timserver time 37/udp timserver rlp 39/udp resource #Resource Location Protocol nameserver 42/tcp name #Host Name Server nameserver 42/udp name #Host Name Server nicname 43/tcp whois domain 53/tcp #Domain Name Server domain 53/udp #Domain Name Server bootps 67/udp dhcps #Bootstrap Protocol Server bootpc 68/udp dhcpc #Bootstrap Protocol Client tftp 69/udp #Trivial File Transfer gopher 70/tcp finger 79/tcp http 80/tcp www www-http #World Wide Web kerberos 88/tcp krb5 kerberos-sec #Kerberos kerberos 88/udp krb5 kerberos-sec #Kerberos hostname 101/tcp hostnames #NIC Host Name Server iso-tsap 102/tcp #ISO-TSAP Class 0 rtelnet 107/tcp #Remote Telnet Service pop2 109/tcp postoffice #Post Office Protocol - Version 2 pop3 110/tcp #Post Office Protocol - Version 3 sunrpc 111/tcp rpcbind portmap #SUN Remote Procedure Call sunrpc 111/udp rpcbind portmap #SUN Remote Procedure Call auth 113/tcp ident tap #Identification Protocol uucp-path 117/tcp nntp 119/tcp usenet #Network News Transfer Protocol ntp 123/udp #Network Time Protocol epmap 135/tcp loc-srv #DCE endpoint resolution epmap 135/udp loc-srv #DCE endpoint resolution netbios-ns 137/tcp nbname #NETBIOS Name Service netbios-ns 137/udp nbname #NETBIOS Name Service netbios-dgm 138/udp nbdatagram #NETBIOS Datagram Service netbios-ssn 139/tcp nbsession #NETBIOS Session Service imap 143/tcp imap4 #Internet Message Access Protocol pcmail-srv 158/tcp #PCMail Server snmp 161/udp #SNMP snmptrap 162/udp snmp-trap #SNMP trap print-srv 170/tcp #Network PostScript bgp 179/tcp #Border Gateway Protocol irc 194/tcp #Internet Relay Chat Protocol ipx 213/udp #IPX over IP ldap 389/tcp #Lightweight Directory Access Protocol https 443/tcp MCom https 443/udp MCom microsoft-ds 445/tcp microsoft-ds 445/udp kpasswd 464/tcp # Kerberos (v5) kpasswd 464/udp # Kerberos (v5) isakmp 500/udp ike #Internet Key Exchange exec 512/tcp #Remote Process Execution biff 512/udp comsat login 513/tcp #Remote Login who 513/udp whod cmd 514/tcp shell syslog 514/udp printer 515/tcp spooler talk 517/udp ntalk 518/udp efs 520/tcp #Extended File Name Server router 520/udp route routed timed 525/udp timeserver tempo 526/tcp newdate courier 530/tcp rpc conference 531/tcp chat netnews 532/tcp readnews netwall 533/udp #For emergency broadcasts uucp 540/tcp uucpd klogin 543/tcp #Kerberos login kshell 544/tcp krcmd #Kerberos remote shell new-rwho 550/udp new-who remotefs 556/tcp rfs rfs_server rmonitor 560/udp rmonitord monitor 561/udp ldaps 636/tcp sldap #LDAP over TLS/SSL doom 666/tcp #Doom Id Software doom 666/udp #Doom Id Software kerberos-adm 749/tcp #Kerberos administration kerberos-adm 749/udp #Kerberos administration kerberos-iv 750/udp #Kerberos version IV kpop 1109/tcp #Kerberos POP phone 1167/udp #Conference calling ms-sql-s 1433/tcp #Microsoft-SQL-Server ms-sql-s 1433/udp #Microsoft-SQL-Server ms-sql-m 1434/tcp #Microsoft-SQL-Monitor ms-sql-m 1434/udp #Microsoft-SQL-Monitor wins 1512/tcp #Microsoft Windows Internet Name Service wins 1512/udp #Microsoft Windows Internet Name Service ingreslock 1524/tcp ingres l2tp 1701/udp #Layer Two Tunneling Protocol pptp 1723/tcp #Point-to-point tunnelling protocol radius 1812/udp #RADIUS authentication protocol radacct 1813/udp #RADIUS accounting protocol nfsd 2049/udp nfs #NFS server knetd 2053/tcp #Kerberos de-multiplexor man 9535/tcp #Remote Man Server ==See also== *[[C/SIDE server]] *[[DHCP]] *[[Network]] *[[Hosts and services]] [[Category:Server]] Источник http://wiki.dynamicsbook.com/index.php?tit...ts_and_services
