emeadaxsupport: Use Windows Performance monitor alerts to start an Dynamics AX ETL trace (Trace parser)
Источник: http://blogs.msdn.com/b/axsupport/ar...ce-parser.aspx
============== Description: In this article, I describe how you can activate and catch an AX trace based on an alert raised. There are situations where you need to collect a trace for a short period example during high CPU usage. The moment is hard to catch if it is not 100% predictable. In these cases, you can use the standard Windows Perfmon alert trace, where you add the counters you want to trace and when the threshold exceeds, another process is activated. How to set it up: AXTRACE
AXTRACE ![]() HIGHCPUALERT ![]() The above is only an example. Many different counters can be used and different actions can be executed when an alert is raised. Author: Kim Truelsen, Microsoft Date 10/11-2015 Источник: http://blogs.msdn.com/b/axsupport/ar...ce-parser.aspx
