palleagermark: Fix synchronization issue with fields in the AOT but not on SQL Server
Источник: http://www.agermark.com/2015/05/fix-...th-fields.html
============== Recently I was called in to help on an issue after installation of a third party module, where fields were in the AOT but wasn't synchronized to SQL Server. The fields also looked as they should in the SQLDictionary table. New attempts to synchronize the database didn't create the fields on SQL. AX must have been under the impression that the fields were synchronized. If I tried to delete any of the fields, I'd get an error from AX about it not being able to drop the fields on SQL Server, so I was kind of stuck. Here is what I did to fix the situation:
I never did figure out how the third party vendor brought themselves into this situation though. That would have been interesting enough to know. Источник: http://www.agermark.com/2015/05/fix-...th-fields.html
Опции просмотра | |
