palleagermark: Build a valid file name
Источник: http://www.agermark.com/2015/02/buil...file-name.html
============== I could find anything in AX building a true valid file name. That is only the name of the file itself, not the path. So I came up with this: public static Filename buildValidFilename(str _filename) { #xppTexts #define.LeftSquareBracket('[') #define.RightSquareBracket(']') Filename validFilename; str invalidFileNameChars; new InteropPermission(InteropKind::ClrInterop).assert(); // Remove the characters that .NET defines as invalid invalidFileNameChars = new System.String(System.IO.Path::GetInvalidFileNameChars()); validFilename = System.Text.RegularExpressions.Regex::Replace(_filename, #LeftSquareBracket + invalidFileNameChars + #RightSquareBracket, #emptyString); // Remove the characters that .NET doesn't remove invalidFileNameChars = @'"\\/:*?\|' + "'"; validFilename = System.Text.RegularExpressions.Regex::Replace(validFilename, #LeftSquareBracket + invalidFileNameChars + #RightSquareBracket, #emptyString); CodeAccessPermission::revertAssert(); return validFilename; } Источник: http://www.agermark.com/2015/02/buil...file-name.html
