Старый 29.07.2014, 04:26   #1
The Costing Error Detection and Data Correction white paper and report has been updated for Microsoft Dynamics NAV 2013 and 2013 R2.
The Costing Error Detection and Data Correction white paper discusses common inventory costing issues and how you can correct erroneous data after inventory costing issues have been identified. The white paper focuses on the data and the fields that typically cause problems in the cost adjustment process.
The Costing Error Detection report can help you find common costing data problems. If the report shows that there are errors in your database, you can use the suggestions in the white paper to correct the data. The report can also be used to validate inventory data after an upgrade.
To review the white paper and download the report for Microsoft Dynamics NAV 2013 and earlier versions, go to:
Источник: http://feedproxy.google.com/~r/Micro...amics-nav.aspx
Часовой пояс GMT +3, время: 00:37.
