Старый 30.04.2014, 16:11   #1
palleagermark: Discarding merge of a changeset in TFS
Источник: http://www.agermark.com/2014/04/disc...et-in-tfs.html
On a project I work on, we have just had the first branch of my life. The merge features in TFS helps me merge needed changes between the two branches and it works just perfect.
As part of the branch I have had to assign a particular range for label id's in one of the branches. This is to avoid conflicts when merging the label files. You set up the label id range from Version Control / System settings / General. Changing this, triggers a change to VCSDef.xml which is also under version in TFS.
This is obviously not a change that I'd ever want to merge. Fortunately there is a way to tell TFS to discard the change when suggesting what to merge. There is no UI for the command, so open a Visual Studio command prompt from the workspace folder to use and enter the following:
tf merge /discard /version:C1134 /recursive SourceBranchName TargetBranchName
This also triggers a change, so you must check that change in. And that's it. The changeset is not suggested for merge between these branches again.
goshoom: Merging concurrent changes in AX with TFS Blog bot DAX Blogs 0 02.02.2014 03:23
Leon's CRM Musings: TFS For CRM Development Management Blog bot Dynamics CRM: Blogs 0 14.01.2014 18:11
Microsoft Dynamics CRM Team Blog: Form Merge Post Upgrade Blog bot Dynamics CRM: Blogs 0 23.10.2013 09:11
palleagermark: Using Team Foundation Service with AX 2012 Blog bot DAX Blogs 0 03.08.2012 12:11
Dave Froslie: TFS Express – now a reality! Blog bot DAX Blogs 0 03.03.2012 01:11
Часовой пояс GMT +3, время: 12:17.
