Старый 14.09.2013, 03:26   #1
How to compare two records of the same table
Источник: http://alexvoy.blogspot.com/2013/09/...ame-table.html
Amongst other mundane chores, from time to time AX consultants and programmers need to check if two table records are indentical and what the difference is if they are not.
Here is a small project for AX 2012 with tmxTableBufferOperation class that provides the following static methods:
  • getOneRecordFieldList(Common _record1)
  • getTwoRecordsFieldList(Common _record1, Common _record2)
  • areIdentical(Common _record1, Common _record2)
  • getDifference(Common _record1, Common _record2)
Their names are mnemonical so you won't misunderstand what they do.
There is also a batch demonstrating how to use them:
The main idea is to use reflection DictTable class to enumerate all the fields of the given table buffer and then populate containers with its field ids, names and values.
 static public List getTwoRecordsFieldList(Common _record1, Common _record2)
    Common              buffer1;
    Common              buffer2;
    List                list        = new List(Types::Container);   //list of all the fields, field names and values
    List                bufferList  = new List(Types::Container);   //final list of all the fields, field names and values of these two records
    ListEnumerator      le;
    int                 i;
    fieldId             fieldId;
    DictTable           dictTable;
    DictField           dictField;
    container           c;
    if(_record1.TableId != _record2.TableId)
        error(strFmt('Both records are supposed to be of the same table type!'));
    dictTable = new DictTable(_record1.TableId);
    if (dictTable)
        // create the list of all the fields in the table
        for (i = dictTable.fieldCnt(); i; i--)
            fieldId = dictTable.fieldCnt2Id(i);
            dictField = new DictField(dictTable.id(), fieldId);
            list.addEnd([fieldId, fieldId2name(dictTable.id(), fieldId)]);
        buffer1 = dictTable.makeRecord();
        buffer2 = dictTable.makeRecord();
        select buffer1 where buffer1.RecId == _record1.recId;
        select buffer2 where buffer2.RecId == _record2.recId;
        le = list.getEnumerator();
        while (le.moveNext())
            c = le.current();
            bufferList.addEnd([[conPeek(c,1), conPeek(c,2), buffer1.(conPeek(c,1))],
                               [conPeek(c,1), conPeek(c,2), buffer2.(conPeek(c,1))]]);
    return bufferList;
Последний раз редактировалось mazzy; 05.11.2013 в 14:43.
Старый 14.09.2013, 12:47   #2
gl00mie is offline
gl00mie
3,684 / 5813 (201) ++++++++++
Сообщение от Blog bot Посмотреть сообщение
В 2012-й с учетом наследования таблиц такого сравнения уже недостаточно, потому что на вход могут подать два буфера родительской таблицы, которые содержат записи из разных производных таблиц, и тогда простое сравнение по полям будет некорректно.
А вот ни разу это не даст полный список полей в случае с таблицей в иерархии наследования. Нужно еще проверить, есть ли у нее родительская таблица, и при необходимости дополнить список ее полями, и так - до корневой таблицы в иерархии. См., например, \Classes\SysDictField\findFieldById. Еще непонятно, почему было не воспользоваться dictField.name().
Последний раз редактировалось gl00mie; 14.09.2013 в 12:53.
За это сообщение автора поблагодарили: wojzeh (1).
Старый 16.09.2013, 22:17   #3
wojzeh is offline
wojzeh
Аватар для wojzeh
681 / 517 (19) +++++++
Дельные замечания!
Про наследование таблиц, думаю, верно. Я взял кусок стандартного кода, уж не помню, из какого класса и убрал для простоты ту часть, которая бежит по "вложенным полям".
функцию нейм() не использовал, потому что балбес.
Felix nihil admirari
How to make a temporary instance of a database table to be shown on the form Blog bot DAX Blogs 0 02.03.2012 01:18
Paint it black: How to color rows in Table form control Blog bot DAX Blogs 0 12.07.2011 02:11
Pawan's Ax blog: How To Restore Data In AIFSchemaStore Table Blog bot DAX Blogs 0 01.07.2010 22:07
Leon's CRM Musings: How to Find the Total Number of Records in an Account, Contact or Lead view Blog bot Dynamics CRM: Blogs 0 01.07.2010 10:05
Часовой пояс GMT +3, время: 18:08.
