Axilicious:System.Diagnostics.StopWatch
Источник: http://www.ksaelen.be/wordpresses/dy...ics-stopwatch/
============== I often see code that still uses the WinApi::GetTickCount method to measure an interval of time. And though there is nothing wrong with it, I wanted to show an alternative method : the StopWatch already known in .Net for quite some time. The sample below show the usage of the stopwatch while I was testing something out with looping all of the tables in the system: X++: static void FetchTableNames_ModelElementTables(Args _args) { SysModelElement element; SysModelElementType elementType; System.Collections.ArrayList tableNames = new System.Collections.ArrayList(); System.Diagnostics.Stopwatch stopWatch = new System.Diagnostics.Stopwatch(); int64 elapsed; ; stopWatch.Start(); // The SysModelElementType table contains the element types and we need the recId for the next selection select firstonly RecId from elementType where elementType.Name == 'Table'; // With the recId of the table element type, select all of the elements with that type (hence, select all of the tables) while select Name from element where element.ElementType == elementType.RecId { tableNames.Add(element.Name); } stopWatch.Stop(); // Get the time it took elapsed = stopWatch.get_ElapsedMilliseconds(); info(strFmt("Time taken: %1", elapsed)); } Источник: http://www.ksaelen.be/wordpresses/dy...ics-stopwatch/
Расскажите о новых и интересных блогах по Microsoft Dynamics, напишите личное сообщение администратору. Последний раз редактировалось Poleax; 04.02.2013 в 09:29. |
