Старый 14.11.2012, 07:13   #1
emeadaxsupport: Shipping Carrier Interface implementation Ax2012
Источник: http://blogs.msdn.com/b/axsupport/ar...on-ax2012.aspx
Implementation Steps:
1)
Have an environment setup with AX 2012
2)
Go to Start | All Programs | Microsoft SQL
Server XXX | SQL Server Management Studio
3)
Click on Connect
4)
Run the following scripts
  1. CreateShipCarrierRole_20120518-194832-194832_2.txt
  2. MaintainShipCarrierRol_20120518-194832_194832_1.txt
5)
Click on the Plus sign next to
MicrosoftDynamicsAX | Progammability | Stored Procedures
6)
Find the stored procedure called
dbo.MaintainShipCarrierRole
7)
Right-click and select Execute Stored Procedure
8)
Click OK
  • If the scripts are not run an error will occur:
    “Msg 2812, Level 16, State 62, Procedure MaintainShipCarrierRole, Line 102
Could not find stored procedure
'master.dbo.CreateShipCarrierRole'.”
  • Reference Technical white paper: Microsoft Dynamics Ax 2009 Shipping Carrier
    Interface
emeadaxsupport: Shipping Carrier Account Numbers and how they are used Blog bot DAX Blogs 0 05.09.2012 03:40
emeadaxsupport: AX2012 AIF services error - The maximum number of joins allowed (99) is exceeded in the statement. Blog bot DAX Blogs 1 03.07.2012 08:13
workflowax: Creating a Visual Interface for AX2012 Model Importing Blog bot DAX Blogs 1 28.05.2012 08:36
emeadaxsupport: AX2012 and AX2009 or AX4 side by side - AOS performance counters overwritten Blog bot DAX Blogs 0 13.03.2012 18:11
emeadaxsupport: AX2012 purchasing posting types “Purchase Expenditure for product” and “Purchase expenditure, un-invoiced" Blog bot DAX Blogs 0 15.02.2012 07:13
Часовой пояс GMT +3, время: 18:08.
