emeadaxsupport: AX2012 POS: Adding a new line is slow
Источник: http://blogs.msdn.com/b/axsupport/ar...e-is-slow.aspx
============== Issue: When scanning an Item in POS the insert into the line grid seem a bit slow. Solution: In the POS.EXE.CONFIG file change the Pooling to true C:\Program Files (x86)\Microsoft Dynamics AX\60\Retail POS\POS.EXE.CONFIG file Estimated improvement: 30-50% better performance Suggested environment for optimal performance on POS: Hardware requirements for a point-of-sale computer The following table lists the hardware requirements for a point-of-sale register. The requirements apply whether or not an offline database is installed on the register computer. Each register computer that will be used to process card payments must also have Internet access. Item Requirement Processor Minimum: Intel/AMD processor in http://www.cpubenchmark.net/high_end_cpus.html Recommended: Intel/AMD Processor Top 15 http://www.cpubenchmark.net/common_cpus.html RAM Minimum: 2 GB Recommended: 4 GB Available hard disk space Minimum: 30 GB 7200 rpm Recommended: 30 GB SSD Monitor Super VGA (1024 × 768) or higher-resolution monitor or a touch screen monitor Mouse Microsoft mouse or compatible pointing device Author: Kim Truelsen Date: 21/4-2012 Источник: http://blogs.msdn.com/b/axsupport/ar...e-is-slow.aspx
Опции просмотра | |
