ukax: Dynamics AX 2012 Upgrade Workshop
Источник: http://blogs.msdn.com/b/ukax/archive...-workshop.aspx
============== Microsoft Dynamics AX 2012 Upgrade Workshop @ Reading Novotel Monday 12th – Thursday 15th December 2011 Workshop Outline The focus of the Dynamics AX 2012 Upgrade Workshop is to help technical resources understand how to upgrade an existing Dynamics AX implementation to Dynamics AX 2012. The Dynamics AX Upgrade workshop will only focus on upgrading from Dynamics AX 4.0 and Dynamics AX 2009 to Dynamics AX 2012 and will address both Code and Data Upgrade. Framework , Application Foundation and Horizontal Application elements of Dynamics AX 2012 will be the foundational knowledge used in this workshop. Key takeaways from this workshop are: 1) understanding of the upgrade process, 2) knowledge of the major impact areas and how to address them, and 3) patterns to model against. Target Audience This workshop will require both development and technical knowledge. Experienced Dynamics AX Resources with knowledge of at least one prior Dynamics AX version (AX 4.0 or AX 2009) will also be required. Pre-requisites As part of the registration process we ask you to complete the attached survey to establish your suitability and experience in order to attend this workshop. Workshop Costs The cost for the 4 day workshop will be £800 per attendee, this will include coffee’s, lunch and an evening meal as the workshop will run into the early evening. The workshop will be run in the Reading location, accommodation recommendations will follow. Next Actions Complete and return the attached survey to AXTraining@microsoft.com. Once approved you will be sent your formal joining instructions. Источник: http://blogs.msdn.com/b/ukax/archive...-workshop.aspx
