Старый 22.06.2011, 01:13   #1
Microsoft Dynamics CRM Team Blog: Creating Custom Charts ~ Phone Call Duration
Источник: http://blogs.msdn.com/b/crm/archive/...-duration.aspx
Microsoft Dynamics CRM 2011 has got exciting new features that help you create custom charts in a few clicks while you are accessing your records. You then see the custom chart as you view your records.
The out of the box entity “phone call” allows us to create a custom chart. The default setting is to show a call duration in minutes. Let’s have look at the how can we create the chart by duration specifying by number of hours.
1. Go to customization è Customize the system
2. Go to Forms
3. Open main form
4. Add fields
5. Now we have a custom field called “new_durationinhours” and I have kept the display name as “Duration(In Hours)”.
6. Add that field on your form
7. You will notice we already have Duration field OOTB, where the schema name is “actualdurationinminutes”
8. Click on the field; select “Change Properties” in the ribbon. Select Event Tab
9. You will the below screen
10. In the form libraries, Click “Add”. You will see a lookup on web resources
11. In the bottom, Click “New”
12. Add the required information, as below
13. Save the record.
14. Add your Jscript code in the Text Editor
15. I have provided the source code below:
16. Save and publish the record
17. You will automatically be taken to Lookup Screen back, with the name entered for the library
18. Click Ok. You’re library is added to the form.
19. Now in the Event handlers, Click “Add”.
20. Once you click add, you will need to mention the function that you’re going to call.
21. Click OK
22. Save and publish the changes on the form.
23. Now go to Phone call form in customizations (Step 1 - 3)
24. Repeat the steps from (7 – 9)
25. You will see the script library
26. Go to Activities, select Phone call
27. You will Phone call activities listed
28. Create a chart and use that custom field as below in the screen shot.
With this simple walkthrough I hope I have not only shown you how easy it is to create a customized chart. I hope it will give you ideas for other kinds of customization that will make your implementation of Microsoft Dynamics CRM more powerful and useful.
Cheers,
Apurv Ghai
Microsoft Dynamics CRM Team Blog: The future of Microsoft Dynamics CRM Accelerators Blog bot Dynamics CRM: Blogs 0 02.03.2011 04:18
Microsoft Dynamics CRM Team Blog: Microsoft Dynamics CRM 2011 Release Candidate (RC) Announcement Blog bot Dynamics CRM: Blogs 0 15.12.2010 11:11
Microsoft Dynamics CRM Team Blog: Testing your Microsoft Dynamics CRM 2011 Apps Blog bot Dynamics CRM: Blogs 0 01.12.2010 03:14
Microsoft Dynamics CRM Team Blog: Building a Self-Contained Virtual CRM Development Server Blog bot Dynamics CRM: Blogs 0 05.05.2009 10:05
Microsoft Dynamics CRM Team Blog: Workflow E-mail Utilities Blog bot Dynamics CRM: Blogs 0 16.12.2008 23:05
Часовой пояс GMT +3, время: 16:31.
