Старый 08.06.2011, 02:11   #1
daxdilip: Tip - Maximizing Performance of Master Scheduling Job
Источник: http://daxdilip.blogspot.com/2011/06...of-master.html
Issue - We had this issue where Master Scheduling nightly batch job was taking more than 3-4 hours to complete.
Solution - Set up the Helpers count to a number more than 0, in our case 8 was a decent figure as it reduced the job completion time from 4 hours to 45 mins. By setting the helper count, it spawns into multiple threads/multiple tasks thereby making the job quicker.
Старый 08.06.2011, 17:45   #2
Vadik is offline
Vadik
Аватар для Vadik
3,631 / 1853 (69) ++++++++
Спасибо, кэп (с)
-ТСЯ или -ТЬСЯ ?
daxdilip: Tip - How to avoid Overriding of SQL Indexes from AX when a Full Synchronization is done Blog bot DAX Blogs 0 17.05.2011 11:11
daxdilip: Tip - How to avoid Overriding of SQL Indexes from AX when a Full Synchronization is done Blog bot DAX Blogs 0 12.05.2011 08:11
daxdilip: Scheduling a Batch Job through code, Batch Multithreading and creating batch tasks at run time Blog bot DAX Blogs 0 17.02.2011 15:11
emeadaxsupport: Performance Improvement on "Multisite activation – Dimension inconsistency clean-up" Job Blog bot DAX Blogs 0 26.11.2010 00:12
daxdilip: Tip: How to display the AOS Name at the status bar Blog bot DAX Blogs 5 15.11.2010 13:55
Часовой пояс GMT +3, время: 16:41.
