Вернуться   AXForum > Microsoft Dynamics AX > DAX: За рубежом > DAX in English
Старый 29.11.2010, 14:24   #1
SteEng is offline
SteEng
4 / 10 (1) +
Query addField in Business Connector
Hi,
I am pretty new to business connector and I am creating a query where I can't figure out how to call addField in C#.
X++ code is:
query.dataSourceNo(1).fields().dynamic(false);
query.dataSourceNo(1).fields().clearFieldList();
query.dataSourceNo(1).fields().addField(fieldNum(CompanyInfo, dataAreaId));
query.dataSourceNo(1).fields().addField(fieldNum(CompanyInfo, CurrencyCode));
Please give me some guidance how to use
...Call("dynamics", false) ..
and so on
SteEng
Старый 29.11.2010, 15:28   #2
_scorp_ is offline
_scorp_
Аватар для _scorp_
488 / 369 (13) ++++++
Hi. Simple C# example:
IAxapta2 axapta = new Axapta2Class();
axapta.Logon2(userId, pass, companyId, "", "", "", "", null, null, null);
IAxaptaObject axQuery = axapta.CreateObject("Query", "queryName", null, null, null, null, null);
IAxaptaObject axQBDS = axQuery.Call("dataSourceNo", 1, null, null, null, null, null);
IAxaptaObject axQBDSFields = axQBDS.Call("fields", null, null, null, null, null, null);
axQBDSFields.Call("dynamic", false, null, null, null, null, null);
You make use callEx, CreateObjectEx for more "clean" sintax, without null parameters.
За это сообщение автора поблагодарили: SteEng (1).
Старый 29.11.2010, 19:58   #3
SteEng is offline
SteEng
4 / 10 (1) +
Сообщение от _scorp_ Посмотреть сообщение
Thanks Scorp,
What about X++ addLink(fieldNum(Currency, dataAreaId), fieldNum(CompanyInfo, dataAreaId)) ?
SteEng
Старый 29.11.2010, 20:14   #4
EVGL is offline
EVGL
Banned
4,445 / 3001 (0) ++++++++++
FieldNum(...) is an intrinsic function inside of AX. I think you may directly use the known field ID number:
("addLink", 61488, 61488)
Старый 29.11.2010, 20:36   #5
SteEng is offline
SteEng
4 / 10 (1) +
Sorry EVGL,
That didn't work. Exception: Invalid Field/ Related field combination.
STephan
Старый 29.11.2010, 21:12   #6
EVGL is offline
EVGL
Banned
Сообщение от SteEng Посмотреть сообщение
Sorry EVGL,
STephan
Sorry, the right ID would be 61448.
Старый 29.11.2010, 21:45   #7
SteEng is offline
SteEng
4 / 10 (1) +
Thanks,
I should have seen that myself.
business connector
Arijit Basu: DAX 4.01 .NET Business Connector: Microsoft.Dynamics.BusinessConnectorNet Blog bot DAX Blogs 3 30.09.2008 01:17
Inside Dynamics AX 4.0: Working with the .NET Business Connector Blog bot DAX Blogs 0 04.10.2007 05:15
Inside Dynamics AX 4.0: Inside the Business Connector Blog bot DAX Blogs 0 04.10.2007 05:15
Inside Dynamics AX 4.0: The Business Connector Blog bot DAX Blogs 0 02.10.2007 04:49
ALEG: Проект "Фишка недели" и первый пост - Microsoft Dynamics™ AX .NET Business Connector Blog bot DAX Blogs 1 22.11.2006 09:43
Часовой пояс GMT +3, время: 22:54.
