Старый 14.10.2010, 23:06   #1
sumitax: Workflow Installation Steps -AX2009
Источник: http://sumitax.wordpress.com/2010/10...-steps-ax2009/
Here are steps for WorkFlow installation  on Windodows Server 2008 R2:
  1. Run the AX2009 set up and select the EnterPrise Portal  Website to be used for WorkFlow.
  2. Delete the application from the IIS . This is should be something like  MicrosoftDynamicsAXWorkFlow50
  3. Added a “Virtual Directory” to the same site and named the new virtual directory with the same name of the deleted application.
  4. In the Physical path of the virtual directory, point to the installed worklfow folder .This should be under AX Folder .
  5. Convert the new “Virtual Directory” to “Application” by right-clicking that directory and clicking “Convert to Application.
  6. Go to EnterPrisePortal application  ans select “Authentication” under IIS section.
  7. Enable the ASP.NET authentication and Windows Authentication.
sumitax: Enterprise Portal deployment -Steps Blog bot DAX Blogs 0 28.09.2010 03:12
sumitax: Ax2009 Programming – Getting Started book Blog bot DAX Blogs 0 13.08.2010 21:06
Shekhar: Dynamics AX2009 : Standalone Installation on Vista with Role centres and workflow. Blog bot DAX Blogs 0 30.03.2010 15:05
Ошибка бизнес-процесса Tarasov E Dynamics CRM: Разработка 9 18.02.2010 14:02
ax2009 workflow steps Kent DAX: Программирование 0 25.11.2009 18:17
Часовой пояс GMT +3, время: 12:18.
