Kashperuk Ivan: Tutorial: Undocumented behavior of kernel functions min()/max()
Источник: http://kashperuk.blogspot.com/2010/0...havior-of.html
============== I was recently reviewing some code written to be shipped with AX6, and noticed an unfamiliar pattern being used in it. I investigated a bit deeper, and turns out it actually works fine on previous versions of AX as well. I am talking about 2 kernel functions for finding the maximum or minimum of the specified values. The signature of these methods is shown on the below image: As you can see, it takes 2 arguments of anytype, and returns an anytype which is the largest of the two values. But it can accept much more than 2 arguments, even though it is not documented as such. I wrote a small job to showcase this behavior. The code is provided below. You can also download it from my SkyDrive Dynamics AX share. X++: static void Tutorial_MinMaxFunctions(Args _args) { #define.ArraySize(11) Random rand = new Random(); int counter; int arrayInt[#ArraySize]; str arrayIntAsString; int arrayIntMaxValue; int arrayIntMinValue; ; for (counter = 1; counter <= #ArraySize; counter++) { arrayInt[counter] = rand.nextInt(); if (arrayIntAsString) arrayIntAsString += ', '; arrayIntAsString += int2str(arrayInt[counter]); } info("Generated array of integers: " + arrayIntAsString); info("The typical way to find a maximum is by looping through all the values one by one, calling the comparison function multiple times"); arrayIntMaxValue = minint(); arrayIntMinValue = maxint(); for (counter = 1; counter <= #ArraySize; counter++) { arrayIntMaxValue = max(arrayIntMaxValue, arrayInt[counter]); arrayIntMinValue = min(arrayIntMinValue, arrayInt[counter]); } info(strfmt("Max.value: %1 and Min.value: %2", int2str(arrayIntMaxValue), int2str(arrayIntMinValue))); info("Using max and min with 11 arguments works just as well"); arrayIntMaxValue = minint(); arrayIntMinValue = maxint(); arrayIntMaxValue = max(arrayInt[1], arrayInt[2], arrayInt[3], arrayInt[4], arrayInt[5], arrayInt[6], arrayInt[7], arrayInt[8], arrayInt[9], arrayInt[10], arrayInt[11]); arrayIntMinValue = min(arrayInt[1], arrayInt[2], arrayInt[3], arrayInt[4], arrayInt[5], arrayInt[6], arrayInt[7], arrayInt[8], arrayInt[9], arrayInt[10], arrayInt[11]); info(strfmt("Max.value: %1 and Min.value: %2", int2str(arrayIntMaxValue), int2str(arrayIntMinValue))); info("Note that comparing an integer and a real also works, as well as outputing the results straight into an infolog message"); info(max(12, 12.001)); } Disclaimer: Since this is not a documented feature, it can theoretically change in the future releases, but I doubt it in this particular case. ============== Источник: http://kashperuk.blogspot.com/2010/0...havior-of.html
