Старый 20.09.2009, 17:05   #1
msdynamicsax: Convert WebForms into .NET User Controls
Источник: http://msdynamicsax.wordpress.com/20...user-controls/
As some of you might have noticed the use of web elements in the AOT in the next version of Ax will be gone. This means that all of the Enterprise Portal development has to be done in .NET.
If you are working with Ax 2009, I strongly reccomend that you convet all your webforms into .NET user controls now. I have also found this nice feature that does this conversion automatically.
Simply import the attached file (rename the filetype from doc to xpo first) and edit the method getFormsToConvert and list all the webforms you want to convert.
Then simply execute the class.
The class described in the SDK as well and I would not be surprised if it is included in the next service pack.
SysEPWebFormConverter
.net, control, webform
epblog: Sharing Code between User Controls in EP Blog bot DAX Blogs 0 11.11.2008 08:05
dax-lessons: Alert user using Net send - x++ Blog bot DAX Blogs 0 17.09.2008 13:05
msdynamicsax: User Interface Blog bot DAX Blogs 0 04.04.2008 11:05
Inside Dynamics AX 4.0: The Security Framework Blog bot DAX Blogs 0 31.10.2007 11:40
Часовой пояс GMT +3, время: 12:00.
