Старый 22.01.2009, 05:06   #1
Microsoft Dynamics CRM Team Blog: Linked Entity Column Data in Advanced Find
Источник: http://blogs.msdn.com/crm/archive/20...nced-find.aspx
Why do I not see any linked entity columns data in either advanced find or by customizing system views for Activities (Emails/Appointments etc…) (after adding related entity columns)?
Problem:
Microsoft Dynamics CRM 4.0's FetchXML does not retrieve Link-Entity data for all activity entities (Appointment, E-Mail, Fax, Phone call, etc.)
When you use advanced find or customize the out of box views to add linked entity columns, say for e.g.: on an appointment you add the regarding Lead’s company name, this column comes up blank.
Cause:
We currently use QueryExpression and this has a limitation of not handling linked entity column set so all the linked entity columns are returned blank. CRM platform code does not return any party info data in case we use EntityExpression as it removes them in ProcessAggregates extension.
Fix:
In case we have any linked entity columns the fix now uses EntityExpression and this successfully retrieves the linked entity columns data. Now come the party info fields which will not be returned if we use EntityExpression.
This fix checks if the fetch has any party info fields and if so, only then makes an additional call to Activity Service to get the party info for the retrieved activity ids returned by the EntityExpression above. The list of activity ids for which we need to retrieve the party info fields is limited to the page size of records which has a default value of 25 and a maximum of 250 records. This additional call will be made only if the fetch has any linked entity columns.
Where can I download this fix from?
The KB number for this bug is 959419 and this is part of CRM 4.0 UR2 and please contact your support personnel if you need more details on downloading this fix.
Thanks,
Chandra Akkiraju
Microsoft Dynamics CRM Team Blog: Microsoft Dynamics CRM 4.0 Bookshelf Blog bot Dynamics CRM: Blogs 1 22.01.2009 04:46
Microsoft Dynamics CRM Team Blog: “Poor man’s” Business Intelligence for Microsoft Dynamics CRM Blog bot Dynamics CRM: Blogs 0 30.12.2008 04:30
Microsoft Dynamics CRM Team Blog: Data Migration Manager Tips and Tricks Blog bot Dynamics CRM: Blogs 0 02.09.2008 22:05
Microsoft Dynamics CRM Team Blog: Top 14 Microsoft Dynamics CRM Sites and Downloads Blog bot Dynamics CRM: Blogs 0 14.07.2008 13:05
Часовой пояс GMT +3, время: 01:34.
