Старый 01.11.2007, 05:40   #1
Dynamics AX: SQL Quick tip - OpenQuery
Источник: http://dynamics-ax.blogspot.com/2007...openquery.html
Alright, it's been a while since I had to do this, but just in case. If you are in an implementation and you happen to be moving data from Oracle or and AS/400 and want to query the tables and views, first:
  • Take and create a linked Server, with the correct provider to the database.
  • Make sure to make use of the openquery syntax
The syntax for openquery goes: select * from openquery(Linked_Server,'Select Statement')
This will save a lot of pain, and allow the other server to handle servering up table attributes, data types and the likes that will cause issues if you try a standard linked server, FQN statement. :-)
Check back soon!
Find a job at: www.DynamicsAXJobs.comFind a job at: DynamicsAXJobs.com, also post a job for only $99.00!
Dynamics AX: Dynamics AX 2009 & SQL Server 2008 Blog bot DAX Blogs 0 10.06.2008 21:08
Inside Dynamics AX 4.0: Usage Scenarios Blog bot DAX Blogs 0 04.10.2007 05:15
Dynamics AX: SQL Server, Heart of Dynamics AX Blog bot DAX Blogs 0 13.07.2007 18:00
Dynamics AX: Quick Tip - Application Object Blog bot DAX Blogs 2 01.06.2007 10:21
Часовой пояс GMT +3, время: 02:29.
